I have always heard that you mount the carbon fiber plate even with the bottom of the boat but I'm making a jacking plate for mine with 3/4 inch of travel up and down. Hope that helps
Ose mini outboard
A good height to start with is to set the prop centerline even with the
keel of the hull, then later try moving the motor a little higher up.
This motor works great on 3S; 2S is not enough.
Check to see that the cable is greased.
West Marine Teflon equivalent wheel bearing grease works well.
Verify that your water pickup on the lower unit is facing upstream;
one of my three was pointing downstream.
Yes, use the Y adapter.
Use Corrosion X before and after each outing.Comment
There are two differnt small OB's and one looks more scale kind of. The OB Steve sells at OSE looks to have something other than brass at the output??
this is the one similar if not the same as OSE except the brass at the o/p.
http://hobbyking.com/hobbyking/store...Motor_Set.html
OSE:
http://www.offshoreelectrics.com/pro...prod=ose-80980
Then there is this one at HK:
http://hobbyking.com/hobbyking/store...0kv_Motor.html
Which one of these is on the 26" green mono shown in this thread????Nortavlag Bulc
24 R/C vehicles and still counting...What budget?Comment
Can somebody please?
I am so wanting to start a twin OB build on a Pursuit hull, but I am torn between using two TFL mini or just one O.S. OB. I want the props to C.Rotate and don't know if one can get correct cables or not. Also the TFL uses .130 cable, how reliable are these?
What about this? http://www.offshoreelectrics.com/pro...d=ose-80915-v2Too many boats, not enough time...Comment
Tfl does have reverse square drive. They need to be cut to length since made for the Zonda cat. I had a reverse tfl cable omewhere that was accidentally shipped with a boat i converted to 3/16".Nortavlag Bulc
The yellow Pursuit in the picture had a ride problem and the owner was raising the OB, wonder how much can one raise, the transom shot looked like both prop shafts were well below the keel line. I asked for updates on his thread but so far no answer yet.Too many boats, not enough time...Comment
Concerning the drive shafts, one end is square crimped for their captive drive system. Are you saying the TFL outboards have each end square crimped?
Yes, for some reason he does not post much of his build and setup. Its a conspiracy! Lol... No info of setup on green 26" Bling Rocket with OB or the yellow twin by the Dutch guy..... Maybe they will chime in, maybe not???
I'd like to do my Rocket with an OB as I've already said but, more info required.Nortavlag Bulc
Ray, I don't know, I thought it may be similar to the O.S., I wasn't thinking... as usual...
Also I wonder if there is up gradable out runner for the unit.
My very original thought was to get the V1 Shock Wave 26 with the open cockpit for the "cool" factor, but no luck getting that hull and next choice was the Aeromarine Challenger. But I acquired a Pursuit ........Too many boats, not enough time...Comment
I'd like to do my Rocket with an OB as I've already said but, more info required.24 R/C vehicles and still counting...What budget?Comment
I have a ski-vee 10 that was built back in the early to mid 80's and was skinned with 1/64 light ply. I have recently rebuilt the drive train and put a 2200kv atomix motor into it with a .098 ose flex cable going to a proboat black widow modified stinger . the boat hasn't seen water in over 15 years and in the last week has been out trying to set it up. this hull loves to ride on the transom and I have avoided putting trim tabs on it as its a small transom but after yesterday I am designing and building tabs for it. flipped it three times on the same battery and got up to 53kph and feel with trim tabs I can probably get more out of it.
hope your enjoying yoursComment
Great little ride you have there John, love watching it run. Trim tabs will help a bit. Just some 1/2" x1/2" angle aluminum will work. I have a bunch from HDepot.Nortavlag Bulc
