twin brushless mini wildcat build
  • Icemans7
    • Sep 2013
    • 15
    Here is my mini wildcat build, thanks to 1 fast guy. I changed my up a little and im currently running a 3 cell, the boat is crazy fast. the boat is pretty unstable after 90/100 percent throttle any way to make it better without loosing top speed? thanks - Mike D.
  • Icemans7
    • Sep 2013
    • 15
    AquaCraft's Mini WildCat converted to brushless motors.
    Two Tacon 2040-3835KV Brushless Motor .
    Two HobbyWing 2040 130 Aluminum Cooler.
    Two HobbyWing Seaking-25A Brushless ESC
    Two Octura .098 flex cable with 1/8" prop shaft (one lefthand, one right hand rotation.
    Two Octura x430 propellers, right and lefthand rotation.
    Ose mini rudder , stock one ripped off with the 3 cell : )
    Ose water pick up and water fittings.
    octura autobailer (best invention ever!!)
    motors are moved forward about 5/8" one speed control in front of motor mount and one on back side.
    (I didn't have the patience to fit all of the running hardware in the stock 2 holes so I cut the area out and used 3/8 wide closed cell foam aroud canopy to keep out most water and the little bit that does get in the auto bailer kicks out)
    • Icemans7
      • Sep 2013
      • 15
      Crrently my props are set up left side clock wise right cc wise, Any one do any experimenting running opposite?
      • Mgivens
        • Aug 2013
        • 32
        Very cool, more pics or a vid would be great!
        I would definetly try switching the rotation up and see how that effects performance!
        • czegard
          • Nov 2012
          • 151
          Post a video!
          Sent from my GT-N7000 using Tapatalk 4
          • Icemans7
            • Sep 2013
            • 15
            http://www.youtube.com/watch?v=sFt2XoxmlOU here is a short video I put on youtube more to come!
