How to bind atomik barbwire????????
  • shartinspartin
    • Aug 2013
    • 257
    My tx broke and I got a new one under warranty. Now I cant figure out how to bind the friggin thing.
    Someone please help!!!!
  • kevinpratt823
    • Aug 2012
    • 1361
    I'm guessing you haven't checked the manual, which is also available on their site, this is from page 5.
    The binding process ties the transmitter and receiver together. Under normal circumstances, both items are
    supplied like this from the factory. If, however, you nd that your transmitter and boat are not
    communicating (receiver’s red LED light is on), please follow these instructions:
    1. Switch “ON” the transmitter.
    2. Switch “ON” the receiver by attaching the 11.1V LiPO battery pack’s connector to the matching connector
    in the boat.
    3. Press down the “BIND” button on the receiver. The receiver’s green LED light will be on to indicate that
    binding has been successful and the receiver will now accept commands from the transmitter.
    NOTE 1: During the binding process, the transmitter and receiver should be no more than 3ft. apart and no
    other similar devices should be within 35ft.
    NOTE 2: If the green LED light is ashing, the binding process has failed. Please repeat the steps above.
    My private off road rc track
    • shartinspartin
      • Aug 2013
      • 257
      I did read the manual and its not working. The light flashes red 3x and green 1x over and over. It gets a little signal for the second it flashes green then nothing
      • kwiktsi
        • Sep 2008
        • 578
        Is the RX dry inside? I have found that my barbwire RX will flake out like that if it gets moisture in it.
        My favorite search engine http://google.com
