Thanks Rob i do count my blessings. glad you love the island.
Every outing i flush my cooling system and clean the flex shaft and grease it, then i spray corrosion x on all metal parts, dry everything and cover just to keep the dust at bay. salt water is very insidious, it takes just 10min before rust starts accumulating on some metal parts. i mostly use aluminum on my cooling system to avoid rust. If you saw rust on your water outlet, that is because the metal is made from 304 stainless which is prone to some rust, i have seen some at times on my Miss Geico cat.
