HK New ECO
  • cpgise
    • May 2010
    • 90
    #31
    Gromov do you have any pics of the bottom of the hull? Also I made a cooling coil a long time ago where I think I wraped the aluminum tubing around a "d" battery for a 540 brushed motor. From what I remember it's slightly smaller in diameter so it fits snug. I want to do this for my 28mm motor. Do you guys think I should find something a little smaller than 28mm and wrap it around that?
    • Gromov
      • Aug 2012
      • 49
      #32
      Ideally - need to buy a cooling for this motor here, or here.
      If you do own - we have to take the mandrel by 1-2 mm less than 28 mm. Since the diameter of the tube is wound is not great, you will run into difficulties at the start of the winding. First round - the most difficult. aluminum tube can bend.
      To prevent this from happening - I inserted the tube at 100 - 150 mm in depth, plastic cord diameter slightly smaller than the hole in the tube. started to make 0.5 turns - then pulled the cord and then everything went smoothly ....
      ecomaster.torgg.com
      • sailr
        • Nov 2007
        • 6927
        #33
        Correct URL for SuxFly is: http://suxflyhobby.com/en/index.shtml
        Originally posted by SweetAccord
        Those are good motors! I have two of em. They are really Suxfly motors but the pic does not show that and HK put their logo in it. They are made by www.suxfly.com. That motor is rated at 14.8v 2~4s. 2s may be ok, but 3s should be a sweeter spot to run at for that hull size, and to get the most out of that motor but prop down as a start. 29000 RPM should not be too bad with 3s on that hull size but I think you can go more in KV. Here is video with similar hull in length with 4100kv motor on 4s.
        With 3s maybe start with a 27mm and then try a 30 mm prop. and work your way up. You will likely need to use a 40A but that may be cutting it close, a higher amp like 50-60A or higher would be much better. Use whatever batter you have that is a highest C rating but is not too heavy, maybe start with a 2200mah to keep it fast and light, but if runtime is short go to higher mAH.
        Some video's and other setups: (Hull: ETTI Tsunami)
        Motor: ETTI 4100Kv, ESC: ETTI 90A, Lipo: 2s 5000mAH Flightpower, 30 mm prop. > http://www.youtube.com/watch?v=DmBQ2FweGwk
        Motor: ETTI B29 4650kv, ESC: ETTI 90A, Lipo : 2S1P 5400mAh, 31 mm prop. > http://www.youtube.com/watch?v=K9REmORI_90&feature=related
        Please keep us posted with your build. I have not found anyone who has one of these hulls and has posted what they have done with em. You may be the first, so it will be nice to see how it turns out!
        Mini Cat Racing USA
        www.minicatracingusa.com
        • cpgise
          • May 2010
          • 90
          #34
          Anyone have thoughts on a decent servo for this hull? Like a hitec or something.
          • Gromov
            • Aug 2012
            • 49
            #35
            Hitec
            Hitec HS 81 or HS 82 Perfect for this hill.
            ecomaster.torgg.com
            • SweetAccord
              Speed Passion
              • Oct 2007
              • 1302
              #36
              Correct as they changed their URL after my post. Thanks!
              • SweetAccord
                Speed Passion
                • Oct 2007
                • 1302
                #37
                I ordered one a few days ago. I'll post some pics when I get it. Looks like you have a few minis. Any Eco builds? I'm trying to figure out where to mount the hardware for this hull. I found other Eco build but they all are shorter.
                Any progress?
                • cpgise
                  • May 2010
                  • 90
                  #38
                  I installed the rudder, just waiting for the servo and linkage. It looks like the majority of the builds use ball cups and tie rods, for lateral movement? I was thinking of using metal rod but was concerned about strain on the rudder housing. I did find another build, look in the files tab on hobbyking, under this hull.
                  • cpgise
                    • May 2010
                    • 90
                    #39
                    Received my servo and a assortment of tie rods from hobbyking. Now I need to figure out a servo mount. I did get my jet boat running though. It was great until my servo mount broke. Here's the vid link http://m.youtube.com/index?&desktop_...?v=7Luo5nVtET0
                    • BILL OXIDEAN
                      Banned
                      • Sep 2008
                      • 1494
                      #40
                      Spoke to Darin Jordan, he gave me a format a while back to re-write Eco and put it up for proposal.
                      Gromov, you should be Particularly interested in this as we would appreciate your input. You guys seem to be taking an interest, so lets facilitate..
                      • cpgise
                        • May 2010
                        • 90
                        #41
                        Here's the servo mount done. Next water pick up and that's pretty much it!photo_edited-1.jpg
                        • cpgise
                          • May 2010
                          • 90
                          #42
                          Finally had time to finish it. Will test it this weekend with video.
                          • BHChieftain
                            Fast Electric Addict
                            • 1969
                            #43
                            Can't wait to see her run!
                            Chief
                            • Gromov
                              • Aug 2012
                              • 49
                              #44
                              This not ECO, but wery funny!
                              ecomaster.torgg.com
                              • sailr
                                • Nov 2007
                                • 6927
                                #45
                                Wow! That takes some skill! Nobody does anything like that in the U.S.A.
                                Mini Cat Racing USA
