Seem as if this is the only forum familiar with Joysway. Anyone know what protocol their transmitters use? Thanks.
Joysway transmitter protocol
Last edited by MassiveOverkill; 06-09-2012, 09:05 AM. Reason: We're not just talking about protocol anymoreTags: None -
I have the smaller plastic mono (magic vee) and its amazing for its size..
Amazingly though I race for Venom they allow me to run Joysway boats because Airtronics was providing them for me..
Let me take a look at that drive and I'll have a solution for the shaft..Comment
I managed to find a grub screw, grind it down and I'm waiting for the loctite to dry.
Here's my idea to convert my flex shaft to semi-straight:
Brass tubing to replace a section of the teflon tube:
Cut off a section of the teflon tube to support the end going to the motor and replace the majority of the teflon tube with the brass:
The idea here is that since my setup doesn't have a curved brass tube, but a stainless straight stuffing tube, I don't need flex but at the very end where it meets the motor. By eliminating the middle part of the teflon tube, and replacing it with brass tube, which is free to spin with the flex cable, you eliminate alot of the friction of the flexshaft rubbing in the teflon tube. Only the ends would have to be lubricated intstead of the whole shaft. I could place a lubrication port just in front of the teflon tube at the rear, and the front teflon tube I should be able to pull out and lubricate without having to take it apart.
What do you think?
Here she is completed:
It doesn't even touch the stuffing tube sides when installed.........I may just leave it free-floating at the motor end:
That's a good look! looks like you've got it covered!
Joysway boats are amazing, the drive systems are the only thing that needs Americanizing..Comment
Funny you mention that. Took her out for her first run..............this thing flies.........but it looks like the .25 cent\hour labor forgot to lubricate the motor bearing:
Yikes! time for another HK motor or some surgery..
Better yet! Contact Boca Bearings, and you'll be upgrading that little motor to some faster more reliable bearings. A lil heat on the endbells pops the old ones out..Comment
Dude, you must have ESP or something!!!
Boca Bearings company is the leader in ceramic and ceramic hybrid ball bearing supplier and technology for industrial, recreational and RC hobby applications.
I was looking at replacing the motor, but the motor is fine, just the bearing is bad. I thought about a HK motor, but I doubt I'd be able to find something to fit the stock motor water cooler I'd have to find some way to mount it (first day of ownership and I've already done too much modding), so re-using the existing motor, which is plenty fast for me, is appealing.
BTW the motor cooling water block probably isn't that effective. There's too much air between the motor bearing housing and the water cooler jacket.Comment
Novak uses a thermal transfer tape like substance that you may fare out well with spacing between the motor and the heat sink.
My uncle makes me remove the anodizing of the mating surfaces as well..Attached FilesComment
I may melt some solder around the flange to fill the gap. Thanks for the help and suggestions.
So I looked up the model number for the replacement motor and it shows up as CF2812. I look this up and it's very common:
http://www.valuehobby.com/emax-cf2812-outrunner.html
http://www.hobbyking.com/hobbyking/s...er_1534kv.html
Apparantely it has a great power-to-weight ratio but the bearings are cheap as others have stated.
I can't believe the price though, 8 bucks?!
If the motor lasts with the new boca bearings I ordered it may be worth it to just buy a few as spares. If not, I guess I'll have to rig up a new mounting system and go with a better setup.Comment
She's up and running again. Recieved my Boca ceramic bearings and Grayson Hobby Gold 2200 mAh 30C Lipo. After the run, the ESC was warm, but the motor water block was hot to the touch. I have plenty of flex clearance and the flex shaft only touches where the smooth shaft near the prop is inserted into the 1 inch teflon tube. I strongly suggest anyone buying this boat replace the stock bearings.
The Boca ceramic bearings I used are:
SMR693C-YZZ #5 NB2 BG (3x8x4) MM
SMR73C-YZZ AF2 BG (3x7x3) MM
Grayson Battery:
Stock battery weight was 138 grams and the Grayson is 179 grams, and I think the added weight makes the boat completely self-righting.
You can see the boat do flips twice in the video:
Other than the bearing issue, I'm really impressed with this boat. She handles really well and doesn't take on too much water after my lexan cowl mod.Comment
How Joysway takes a 1600KV CF2812 motor and turns it into a 3300KV motor:
Left motor is a standard CF2812 brushless. Right is Joysway frankenbrushless that I can't find anywhere. They removed 6 magnets (14 on left, 8 on right) and beefed up the gauge of the windings:
Motors put back together:
Windings of the stock Joysway Frankenbrushless:
which will lead me to another post about what timing I should use on my ESCComment
Hi Guys,
Over here in the UK Joysway used to sell their kits without RC gear, which is how I bought my Offshore Warrior. Now equipped with 2.4 GHZ cheapie radio from Giant Shark. Now all the Joysway boats come pre fitted with 2.4 gear of their own make. Still haven't managed to get mine on the water due to time. Having recentlly retired, I should now have time to frighten myself to death with this little monster which I told literally flies on the recommended 3S lipo. Since I am a bit out of practice, may start with a 2s and see how it goes!Comment
You guys are lucky as Joysway is readily available over there. I convinced Aaron from Banggood to start carrying Joysway. Good thing about Banggood is that just about everything has free shipping:
Shop for the best rc boat at great wholesale price, Banggood.com offer the cheap remote control boat, rc racing boat and high speed racing boat with worldwide shipping.
He even has the best price on the NQD Tear IntoComment
