Electrified drivetrain recommendations
  • Chenige
    • Jul 2011
    • 172
    OK, been lurking here a little while and am ready to ask my big question. First, I built a Dumas wood atlas van lines sport 40 about 25 years ago. Have extensively modified it over the years with an OPS engine, etc. Have a Seaducer mono and a few other nitro boats. Put the boats away about 10 years ago due to kids.
    About 12 years ago I built up a bunch of Electrified "kits" for my nephews and nieces to build and made up a video building mine for them to watch. I think only one actually built it, but oh well. I have 4 more kits and my 12 year old daughter and 10 year old son want to build them. I figured I would build another for myself. My old one was built with a 19 turn speed gem motor, astro flight ESC and 1500 7.2V niCD. Surface drive.
    Electrified was a boat in the boat RC mag back then. 20" long. Mine scoots along pretty well. Does turn right which I think is due to prop walk so I need to revise somehow.
    So I would like to build with modern electrics which will introduce us into LiPO.
    I am looking for suggestions on batteries, motor, ESC.
    Here is what I think I have found on the forum. I am trying to keep cost down.:
    2 cell liPO Turnigy 5000mAh 2S 20C Lipo Pack
    450 motor ADS300 Water-cooled Brushless Outrunner 3000kv 300w (revised)
    ESC Seaking-25A Brushless ESC for Boat (Version 2.0)
    Anything else I should know?
    thanks, Chris
  • n.h.schmidt
    • May 2007
    • 39
    Electrafied
    Hi Chris
    I rember them well. I made four of them. They were very well suited for N1 and Spec 19 raceing. I raced them for years. Prop walk is a problem for them . Offset thrust helps them run straight. My last one had a steeper V and strakes that went all the way to the transom.That's the only one that tracked straight without any offset. I'm sorry I can't be of any help in the BL motors. Most today are only interested in going as fast as possible. That will not work with this little boat. 30 mph is a wild ride with this one.
    n.h.schmidt
    • Chenige
      • Jul 2011
      • 172
      How much did you have to offset the thrust and how did you do it? Planning on building it like the plans with just a copper tube out the transom which is not easily adjustable . Also considering offsetting the stinger 1/4" to the right of center to see how that works?
      Plans do show the strakes running to the transom. The one I built many years ago did have the strakes to the transom and it goes to right horribly.
      Chris
      • n.h.schmidt
        • May 2007
        • 39
        Offset
        Hi Again
        I made two with just the stinger tube sticking out. They had the center of the tube offset to the right about 1/8". One of them used a aluminum tube for the stinger .I ended up bending the tube to the right to increase the effect. Two others I used strut hardware . They also had the exit offset that amt. The struts were also angled to the right some.
        Sharp metal props also helps reduce the prop walk problem. A X432 is almost ideal for this boat.
        n.h.schmidt
        • Chenige
          • Jul 2011
          • 172
          Thanks, I will move them to the right 3/8" and see how that works.
