or maybe this one if I use the cooling jacket of my old motor ?
Cn anyone please help with the offshore warrior
The first motor is to big as its 34.5mm diam at the water jacket, You wont get the lipo in along side the motor. Plus its to powerfull for the Warrior being a 700w motor. The second Turnigy motor should be ok all be it slightly down on kv bit it only has a 2mm shaft so you need to use a different coupling as the original is 1/8" or 3.17mm. The water jacket on the original motor is bonded on to the motor so you would have to break this seal to get it off, Assuming you can get it off without destroying it you would have to bond it back onto the new motor.Comment
you could try this
http://www.hobbyking.com/hobbyking/s...dProduct=11172
or this
http://www.hobbyking.com/hobbyking/s...dProduct=15185
and for the escs
http://www.hobbyking.com/hobbyking/s...dProduct=10013
or this
http://www.hobbyking.com/hobbyking/s...dProduct=10015
i went for the 2218 and 50 amp esc they are on there way here from hk look to be pretty promising i have the cat and plan on running on 4s with the 2500KV version also bought 2x2s 1800 30c tenergy batteriesComment
