I had a seaking 35amp esc with the lipo cut off, I never had issues with heat on motor, batteries, or esc but usually could tell the battery was getting low buy preformance.
What prop and motor kv are you guys running to get 5 minutes out of a 1300mah pack?
I usually get ~6 minutes on my small bolt, but I'm putting about 1500mah back into a 2200mah pack. I'm running the stock 2700kv motor, and a metal x632 prop (S&B).
Not sure how much lipo experience you have, but try to make sure you're not draining it more than 80% (ie not using more than 1040mah on a 1300mah pack), even if the voltage is still high. Some high C packs (or lower amp draw boats) will totally drain a pack without hitting the LVC.
Light travels faster than sound, so people may appear to be bright until you hear them speak.
I have no lipo experience. Got the lipo for my crawler and never used it. It's still in the box it came in a year ago. Picked up the Micro Hydro yesterday from the local hobby shop. this what should be there. The motor is red, no other markings.
Specifications
Length Overall: 380mm)
Beam: 200mm
Hull - Hand laid fiberglass hull and hatch.
Power - Water cooled, 20mm x 40mm, 2 pole, 2600KV 64g
ESC - Water cooled 30a continuous, 40A (10 seconds), 6-12 NiMh, 2-3 Lipo, 2A-6V BEC, programmable, 27g
Servo - High Performance
Our famous CNC machined hardware.
Drive System - Flex shaft, 4mm prop shaft, drive dog
Propeller - Plastic 30mm x 36mm, 4 different diameters available
REQUIRED: 3S 11.1V Lipo Battery and 2 Ch Radio
For the first couple runs I would suggest making them shorter (2-3 minutes) and see how much current you're putting back into the pack, and up the run time from there.
If you want longer run time, 3s 2200mah packs are like $9 from hobbyking.
It's hard to beat Hobby King, but also HobbyPartz is another one to consider. The Blue Lipo's are excellent performers for the price. Turnigy, Rhino, Zippy are good also. I have only had one Zippy fail on arrival but for the price I can order two to three more and still be ahead on the cost.
Your stock motor is a 2700kv? Interesting, have not seen that yet. Normally it's the 2604kv one I've seen. Where did you get yours?
How do you tell how much you have taken out of the lipo, Does it show on the charger when you charge again. What should i be looking for to see how much has been taken out or needs putting back in on say a 2200mah 3s lipo Thanks.
