Securing the prop.
  • Eggy
    • Jun 2009
    • 152
    Securing the prop.
    What do you guys use to secure your props? Up til now i have been using a standard non lock nut along with the bullet nut, and last run the boat flipped on me doing around 25mph in a turn. Dont know if it was the flipp that coused the prop to come loose or if it was the other way around.
    I usualy thighten the inner nut with a socket along with an extender and tighten it with my hands untill its quite tight, then i use the slighly more pressure on the bullet nut.
    The reason why i dont use a lock nut is becouse the drive shaft is not long enough to use the bullet nut aswell.
    Should i trow away the bullet and just stick with a lock nut or do you have any other tips?
    Thx
  • domwilson
    Moderator
    • 4408
    I use Locktite Blue with a crush nut and/or the bullet. It still holds and is easy enough to remove.
    Government Moto:
    • Flying Scotsman
      Fast Electric Adict!
      • Jun 2007
      • 5190
      Or Permatex purple
      Douggie
      • domwilson
        Moderator
        • 4408
        I'll see your permatex purple and raise you...
        Zap threadlocker blue. http://www.zapglue.com/Thread.html
        Government Moto:
        • Diegoboy
          • Mar 2007
          • 7244
          I have used all types of nuts, and have lost a prop on every one. I took a tip from the Nitro racers, and started using a piece of silicone fuel tubing as a nut. I can safely say that I have never NEVER lost a prop since.
          One day with my Viper, then suddenly no fwd movement. Throttle spun but no movement. I remembered that I had pulled the fuel tubing off to swap props, I put the tubing on the very tip of the prop shaft, and forgot to slide it down to the prop. I thought I lost my first prop on fuel tubing. Got the viper back.
          The prop was still there, the tubing (just on the tip) kept the prop on the shaft. because it wasn't seated all the way, the prop came off the dog is all. Still no lost prop.
          Egneg was there for that famous run.
          There are those that are going to say that it's not a good idea, and it probably isn't. But I can't argue with the results...
          • egneg
            • 4670
            The regular nut and bullet should be fine if you use 2 wrenches and tighten them against each other like you would a flex coupling.
            IMPBA 20481S D-12
            • tharmer
              • 342
              I use a wheel coller. Take a size smaller and drill and tap it to screw onto the shaft. Then use low strength permatex thread lock on the coller allen screw. It's worked so far.
              -t
              • Simon.O.
                • Oct 2007
                • 1521
                For my smaller boats that run a 1/8" shaft I use a small piece of fuel tube on a smooth shaft.
                For the bigger 3/16" shafts I use a very short piece of fuel hose and then a wheel collar pressed up to the tube and tightened.
                As all of my shafts are smooth I can not get a nut on there anyway.
                Makes for quick prop changes and I have not lost a prop yet.
                • Xzessperated
                  • Apr 2008
                  • 3060
                  I have never lost a prop using Nylock nuts. I like Diegoboys way though and will give it a try as it saves a lot of time when testing props
                  Several boats in various stages of destruction
