hydra 240 waterproofing
  • U.L. HYDRO DRIVER ICE
    • Apr 2008
    • 265
    would a water proof box around hydra 240 work or would to much heat build up work/ if not or should I coat it in something
  • Rumdog
    • 6453
    http://www.offshoreelectrics.com/pro...prod=ose-dp270 This works fantastic. I just used it on a Hextronik 120.
      • Apr 2008
      • 265
      So take the shrink wrap off and cooling plate . then 270 epoxy brushed on / thermal paste cooling plate /is this the right procedure / has anybody done this to a castle 240 thanks
      • Rumdog
        • 6453
        Haven't on a 240, but yes that's basically it. I lightly sanded the mosfets to clean the epoxy off them for a good contact with the cooling plate.
        • Gary
          • Jan 2009
          • 1105
          I conformal coat mine. Total mess doing it but totaly sealed.
          H&M 1/8 Miss Bud 73 mph
          Chris Craft 16 mph
            • Apr 2008
            • 265
            which conformal coating and do you have link where to get it thanks
            • Gary
              • Jan 2009
              • 1105
              You can get it in the water proofing section on OFF SHORE. Be prepared though its very slow to dry and always moving around but i have had this done for all my units and never had one fail. They have been under water all night and still work perfect. {Just could not get her back before it got dark} LOL
              Chris Craft 16 mph
              • DISAR
                • Aug 2007
                • 1072
                The hydra CC240 has more than one board there4 conformal coating it might not be 100% effective in SEA water. For sea water I use the box idea.
                http://www.rcfastboats.com/
                • Gary
                  • Jan 2009
                  • 1105
                  No it can be done. I use 1/2 tube of conformal coating and completely saturate the esc. Like i said its a messy deal and i am always scooping up excess goop pouring out during its drying time.
                  Chris Craft 16 mph
                    • Apr 2008
                    • 265
                    Are using the epoxy 270
                    • Gary
                      • Jan 2009
                      • 1105
                      Yes and i have only seen it on Off Shores site.
                      Chris Craft 16 mph
                      • longballlumber
                        • 3132
                        My $.02...
                        Find out why your getting water in the hull and fix it. I would rather have a dry hull than wet electronics...
                        As far as my LV 240; it has been completely submerged in water and it has been "damp" in past experences. I simply take the shrink off, blow all of the excess water off, set it in the sun to dry, and everything is fine. I have been using the same controller for the last 2 years with out one problem.
                        Mike
                        • DISAR
                          • Aug 2007
                          • 1072
                          In fresh water or sea water? I had a reply from Castle that in sea water they sort because the + and - battery terminals are not sprayed.
                          • longballlumber
                            • 3132
                            Disar,
                            My experiences are all in fresh water.
                            Mike
