hobbycity esc
  • screwball
    • Jul 2009
    • 464
    hobbycity esc
    i just picked up a new esc from hobbycity after mine had a meltdown but i wanted to know if im going to need a pistix for it
    this is the esc http://www.hobbycity.com/hobbycity/s...idProduct=6460
    thanks,
    James
  • Jeff Wohlt
    • Jan 2008
    • 2716
    From what I can tell yes it is airplane ESC so not pistol compat.. Or you can rubberband your throttle forward.
    www.rcraceboat.com
    [email protected]
    • screwball
      • Jul 2009
      • 464
      what do you mean by rubberband my throttle forward
      thanks,
      James
      • FRED
        • Jul 2007
        • 233
        hobbycity esc
        You'll regret buying it for boats, i bought one without knowledge and returned it cause it was a ROYAL PAIN 10 years ago or more and almost discouraged me from going FE.
        • Flying Scotsman
          Fast Electric Adict!
          • Jun 2007
          • 5190
          James, what hull are you planting that esc in, motor, batteries,prop? and yes you will need a Pistix
          Edit.......you will not need a Pistix dumb me for not reading a user's report , but I am concerned as far as the application.
          Douggie
          • video200
            • 837
            have that exsact one in my mini C ( coated in epoxy) .HXT 2835 on 2c lipo and it works great with my hitec agressor 40mhz fm without a pistix.
            • 785boats
              Wet Track Racing
              • Nov 2008
              • 3169
              Since it's got a brake enable/disable function, it may be used for cars as well, so it might work on a pistol radio.
              Just a thought.
              That's not a very big ESC for a F/E boat. If the one you fried was the same size you may fry this one too, hence Douggies question in the previous post, I would think.
              Paul.
              Video 2000 posted while I was typing. So there you go, no pistix.
              • screwball
                • Jul 2009
                • 464
                its going in a micro scat cat with a feigao 380 motor on 3s lipo the last one got wet and shorted out
                • Flying Scotsman
                  • Jun 2007
                  • 5190
                  What prop, motor and battery specs. I think that ESC will still go
                  Douggie
                  • screwball
                    • Jul 2009
                    • 464
                    motor is a feigao 380s 3000 something kv and the battery is either a rhino 1550 20c 3s or a rhino 1250 20c 2s im not sure on the prop as i got it second hand but i have a few to play around with so i can prop up or down
                    • screwball
                      • Jul 2009
                      • 464
                      forgot to ad that i will be adding watercooling and also may switch over to a micro patriot hull
                      • screwball
                        • Jul 2009
                        • 464
                        would this esc be any better if so ill cancel my order and get this one
                        https://www.hobbycity.com/hobbycity/...r_(Blue_Series)
                        also as said in my previous post i will be adding watercooling and may switch over to a micro patriot hull eventually or another one like the etti micro that has the flood chamber pre-installed
                        • screwball
                          • Jul 2009
                          • 464
                          no love?
                          • j.m.
                            • Jul 2008
                            • 838
                            Wow, dude. 4 posts... [edit]
                            Um, so yeah. They work fine with pistol tx's. The brake function is not the same as the brake for cars though, it's to slow down a folding prop so it will fold up faster on electric sailplanes.
                            You will want to turn it all the way off.
                            I have the 60 amp version. Waterproofed and watercooled.
                            If your drawing 15-20 amps with that speedo, you'll be fine. Otherwise, go up a size. It's never a good idea to run an esc at full tilt.
                            • screwball
                              • Jul 2009
                              • 464
                              wait so are yo talking about the mystery esc or the hobbycity one?
                              thanks,
                              James
