were to get a lipo cutoff
  • video200
    • 837
    were to get one and witch ones do you guys reccomend ?
  • domwilson
    Moderator
    • 4408
    Here's what I'm using on my SV27.
    Government Moto:
    • video200
      • 837
      thank you domwilson :)
      wil i need 2 to run in series ?
      Last edited by video200; 07-20-2009, 04:31 PM. Reason: never to late to think of another question :)
      • ED66677
        • 1300
        the LipoShiel is for 12S max, why do you want to have 2 in series? this device check the total voltage of one pack!
        the other option is the Cellshield but it is only for 6S max, the good thing is that Cellshield check the voltage of each individual cell of a pack through the balacing tab.
        Emmanuel
        • video200
          • 837
          was if the batteries is beeing run in series. so 1 liposhield on each battery.
          but i read on the site that it is between the ESC and the recever.
          • ED66677
            • 1300
            nope!
            only one device between Rx and ESC, the device change the signal being sent by Rx to ESC when cut-off level is reached, it reduces to throttle, there are 3 connections on Liposhield/Cellshield, throttle input from Rx, throttle output to ESC and battery input voltage for Liposhield or balancing tab input for Cellshield, if you go for the Liposhield you only need to connect the voltage input at the ESC (2 wires) so that it check both batt voltage in series, if you go for Cellshield, you need to make an adapter plug (sort of multi wires Y harness) to connect both balancing tab (of each battery) to the corresponding input connector of the device!
            hope this is clear
            Emmanuel
            • video200
              • 837
              ed.
              you are always clear :D
              i already orderd the liposhield sinse it is to be connected between the ESC and recever.
              • domwilson
                Moderator
                • 4408
                If connecting the liposhield to two batteries in series. Connect the red wire to the positive on 1 pack and the black wire to the negative on the other pack. Do Not connect to the positive and negative on the same pack.
                Government Moto:
                • FRED
                  • Jul 2007
                  • 233
                  lipo cutoff
                  Cleaning house.
                  • video200
                    • 837
                    was under the impression that with teh liposhield it went between the ESC and recever and with that it wouldent se the batteries as 2 packs in series but as 1 pack and would cut when it was down to 3V on each of the cells.
                    • domwilson
                      Moderator
                      • 4408
                      Here is the installation document. You can see where you have to solder to the deans connector in this. The example shows only one connector.
                      Government Moto:
                      • domwilson
                        Moderator
                        • 4408
                        In other words. Solder the red to the positive lead on the ESC and the black to the Negative lead on the ESC.
                        Government Moto:
                        • video200
                          • 837
                          wil do :)
                          thanks for the help guys :)
                          • HOTWATER
                            • Nov 2008
                            • 2323
                            You can buy this one at Kintec Racing...
                            -Kent
                            "Will race for cookies!"
                            IMPBA D12
                            My Gallery: http://forums.offshoreelectrics.com/album.php?u=1738
