8s2p cat
  • NorthernBoater
    • 811
    8s2p cat
    What are the different setups people are using for cats using 8s2p LiPos? I plan on using 4x 4s Hyperion 3300 mah 35C packs.
  • bwells
    • Jan 2009
    • 842
    still learning but is that 29.6 volts and 6600 Mah at the motor?
    • ozzie-crawl
      • Sep 2008
      • 2865
      havent ran 8s but 6s using 4 25c 3300.running 4 smaller packs can be good if there isnt a lot of room to get battrys in sponsons
      • bwells
        • Jan 2009
        • 842
        thats 22.2 assuming you run 6s2p. How do you guys get away with that kind of voltage? do those brushless motors take any thing you can throw at them? I see you are online ozzie, It's 11:30 pm here in Calif, what time do you have in Aus.? P.S. Can you send me a Koala Bear, the wife would love one and so would I!!!
        • ozzie-crawl
          • Sep 2008
          • 2865
          its 4.35 pm here. koala is in the post
          with voltage generally speaking if you run higher volts lower kv motor the less amps you draw.
          • bwells
            • Jan 2009
            • 842
            I'm just starting to learn about brushless but volts seem like the kicker, you can only go so high before you exceed the limits of the motor, I.E don't you need a motor that can handle 30 volts when using 22.2? Thanks for the Koala, do I need to trim it"s claws?
            • ozzie-crawl
              • Sep 2008
              • 2865
              just to give you a rough idea what i mean.
              take a 8xl (2084kv) on 4s with a x440 prop, would pull around 80-90 amps with a speed say around 40-45 mph
              now run a 14xl (1191kv) on 6s with a x445 amps would be around 15-20 amps less but speed around the same. this may not be 100% correct but you get the idea
              • NorthernBoater
                • 811
                I also use the 3300 packs in my rigger they are the only packs that will fit.
