Scorpion Outrunner power in my Rigger
  • Raydee
    • May 2007
    • 1603
    #61
    Hmm the 3026 1900kv might be nice in my 4s Whiplash next season. For $70 its worth a try, does anyonw know if the Scorpion has the same bolt pattern as the Neu 1515?
    Team Liquid Dash
    • Mel279
      • Dec 2008
      • 857
      #62
      hi
      which scorpion outrunner would be good for my triton 31" on 6s?I was thinking of the 4020 1390kv
        • 9488
        #63
        What would be a good sized motor for a Whip40?
        • properchopper
          • 6968
          #64
          I assume you're running more than 4S in the Whip; Jan can chime in & help ( my experience is limited to 4S); He's running one of the 4000 series in his 1/8 scale on 8S & 10S; 1/2 throttle wheelies !!
            • 9488
            #65
            Thanks!
            if you can let me know what motor for sure, I would like to run on 6s..
            but if that wont do it then I will goto 8s..
            1/2 throttle wheelies! dang
            I bet that sucker has some good topend!
            • Ub Hauled
              • Aug 2007
              • 3031
              #66
              Originally posted by Raydee
              How does the motor run without water cooling? I see that they say they can run at over 350* F, that is great. I know outrunner's aren't as efficient as inrunners so I wonder how bad run time suffers. I have run only outrunners in my heli's and they make a ton of power.
              I like the idea of that large outrunner in a 42" Dolphin hydro on 10s.
              Ray, they are MORE efficient then the inrunners in general, there are exceptions as always...
              as far as heat goes, they are rated for 350 (at least some) but I would NEVER ever run them to even 200F purposely... why do it?
              • Ub Hauled
                • Aug 2007
                • 3031
                #67
                it has a 540 bolt pattern... not sure what a 1515 has.
                Originally posted by Mel279
                hi
                Sound fast.
                • Ub Hauled
                  • Aug 2007
                  • 3031
                  #68
                  how heavy is your hull RTR and how many cells are you going to run?
                  • Mel279
                    • Dec 2008
                    • 857
                    #69
                    Scorpion motor a better choice since the shaft can be replace which is what I like. It can be rewind again if I want it to be cooler. 4035 seem to be great also
                      • 9488
                      #70
                      I would like to run 6s
                      • Ub Hauled
                        • Aug 2007
                        • 3031
                        #71
                        I think the Scorpion HK-4020-1390 would be a nice addition to your collection.
                        • Akoni
                          • Sep 2009
                          • 41
                          #72
                          What would be a Scorpion equivalent to say a F580 6L or 7L for use with 4S and 5S?
                          • sailr
                            • Nov 2007
                            • 6927
                            #73
                            The motors being used are the Helicopter motors with the built in fan. I'm not sure there are that many different sizes in them. When you get up into the bigger stuff, it's a normal fixed wing aircraft outrunner without the fan. Cooling could be an issue.
                            Mini Cat Racing USA
                            www.minicatracingusa.com
                            • Darin Jordan
                              • 8335
                              #74
                              Unless they've been changed, the Neu 15-series have a standard 25mm pattern...
                              Darin E. Jordan - Renton, WA
                              • Jeff Wohlt
                                • Jan 2008
                                • 2716
                                #75
                                Not to take away from Scorpion or this thread but now you have me looking at these but this one looks decent and price alone.
                                6S 1800KV?
                                http://www.hobbycity.com/hobbycity/s...0kv_(500_Class)
                                www.rcraceboat.com
                                [email protected]
