51.1mph Triton vid
  • RMZDADDY
    • 379
    51.1mph Triton vid
    I ran my Triton again today with the M645 prop, worked out better than last weeks run. Moved the COG forward to 8.5" and it picked up 3.1mph over last weeks 48mph (thanks for the tip Mr. Smock). Amp average for the run was 54, but at full throttle it looks like it's drawing more like 60-65 amps. I believe I still have some tuning to do to get the hull to turn a little better. Would it be wise to use trim tabs on this hull? Here's the vid.
  • saleens7
    • 1108
    wow thats fast!
    great vid, great driving...
    yeah, i think you might want to use trim tabs....i would keep them neutral though, just so it acts as an extrention of the hull and stableizes it a bit, its not loose enough that it will need that much of a negative angle, i think...
    • RMZDADDY
      • 379
      Thx Saleens, I think you're right, tabs may be the way to go.
      • SJFE
        • 4735
        I am not going to run tabs anymore. I believe that with proper tuning you don't need them.
        • RMZDADDY
          • 379
          I may use them, only after I've made every effort to tune the boat without them. I don't want to add drag to the boat if I don't have to. I may yet try to increase the rpm at the prop with gearing and go back to the X642. The boat seems to turn better with the smaller diameter props.
          • SJFE
            • 4735
            You know what I really want to run. Of of those trimax active ajustable dives. Trim the boat on the fly. I think they are designed for the really big hulls though.
            • saleens7
              • 1108
              actually, they make them in mini, middle, large, and XL sizes....the mini (for boat 32-48") will work with it.....its 130$ though...
              • Doug Smock
                Moderator
                • 5272
                Your welcome sir!!! Great looking mono!!:) Your boat like most other monos, would benefit from the use of trim tabs. There is only one mono( that I know of ) that doesn need trim tabs. Get a set of Fullers or Speedmasters.
                Post a pic or two of your setup for us.
                Doug
                MODEL BOAT RACER
                IMPBA President
                IMPBA 19887L CD
                NAMBA 1169
                • RMZDADDY
                  • 379
                  Here's the latest pics of the boat and setup, I'll be ordering tabs this week. Thanks again Doug:)
                  • saleens7
                    • 1108
                    looks good...the amount of cells you have in that thing is making me drool...
                    • Doozie870
                      • 828
                      "I am not going to run tabs anymore. I believe that with proper tuning you don't need them"
                      __________________
                      Hallelujah!! I thought I was the only one :D
                      • RMZDADDY
                        • 379
                        Yeah, I like running high volts, but boy is she heavy:D
                        • Doug Smock
                          Moderator
                          • 5272
                          [QUOTE=RMZDADDY;6669]Here's the latest pics of the boat and setup, I'll be ordering tabs this week. Thanks again Doug:)
                          You had better go with Fullers, I don't believe you have room for the Speedmasters.
                          Doug
                          MODEL BOAT RACER
                          IMPBA President
                          IMPBA 19887L CD
                          NAMBA 1169
                          • RMZDADDY
                            • 379
                            In the upper 30mph to low 40's tabs didn't seem at all necessary for this hull, tracked straight and turned on a dime. Now that it's broke 50 all that has changed. For the minimal investment, I think I will give the tabs a try, if they don't accomplish anything, I don't have to run with them. I'll let you all know how it goes:D
                            • Doug Smock
                              Moderator
                              • 5272
                              [QUOTE=Doozie870;6673]"I am not going to run tabs anymore. I believe that with proper tuning you don't need them"
                              __________________
                              Hallelujah!! I thought I was the only one :D[/QUOTE
                              Man, I need to go back to FE school. LOL
                              Doug:)
                              MODEL BOAT RACER
                              IMPBA President
                              IMPBA 19887L CD
                              NAMBA 1169
