What boat to use with a 1515 1Y and MMM
  • Kaz the Minotaur
    • Jan 2008
    • 34
    Why are some rudders directly behind the prop and others off to the side?
    I've been trying to browse Ebay to see what is out there but I'm not finding much except toy grade boats...
    • Kaz the Minotaur
      • Jan 2008
      • 34
      So I guess that the 1600KV 80mm Medeusa would be a good choice for 5S also?
      • detox
        • Jun 2008
        • 2318
        Cheaper Feigao is a better choice and just as fast if matched correctly.
        • Kaz the Minotaur
          • Jan 2008
          • 34
          I agree that they are cheaper but I've not had the best luck with quality. Seems like they get hot easily.
          I see a Pro Boat Shockwave 36 nitro on Ebay. Would that be feasable to convery to electric? What all would be involved?
          • sailr
            • Nov 2007
            • 6927
            Generally, centered rudders (behind the prop) are used on Catamaran hulls and the offset rudders on Mono hulls. Why? not sure! Can anyone else help with this?
            You are better off watching the SWAP SHOP here than going on ebay. The guys are not as likely to sell you junk!
            Mini Cat Racing USA
            www.minicatracingusa.com
              Generally, centered rudders (behind the prop) are used on Catamaran hulls and the offset rudders on Mono hulls....
              Actually centered rudders are used on all model types, even hydros. They are used for several reasons:
              - they provide improved low speed steering for small ponds
              - they can, sometimes, give better turnng to the right for offshore racing
              - they appeal to inexperienced boaters who think they look more scale
              For "fast" electric boats they have major liabilities:
              - they are less efficient running in the aerated water coming off the prop
              - they can cause wandering due to the "bubbly" water
              - they cause more drag the offset rudders
              - their longer linkages can have more deflection hurting steering precision
              - they hang further off the transom and are more prone to damage
              I have no problem turning left and right with a right-offset rudder on my cats and monos. It just has to be deep enough on monos to stay in the water during a banking left turn.
              • sailr
                • Nov 2007
                • 6927
                Can't argue with that! :-)
                Mini Cat Racing USA
