Running on the edge, a leaf and a bad day!
  • Simon.O.
    • Oct 2007
    • 1521
    2 points I will pick up on here.
    1. checking the cooling system. As I have less esc's than hulls I swap them in and out a lot and get used to doing a cooling styem check, this is as crude as blowing in one end and feeling the air out the other. I also pre charge most of my hulls with a syringe full of water.
    2. water outlet. Ben raises an interesting point on observation and running styles. I too look ahead of the boat and when it is close I will not see a tell tail from a transom outlet. I may consider moving 2 of mine to the side.
    I have had a feather foul a water inlet and near cook a speedy, I am dang lucky it did its thermal shutoff thing before I could add it to the list of crispied speedies.
    You have got to love those cheap chinese esc's and the thermal shutdown
    • sailr
      • Nov 2007
      • 6927
      I am starting to put my water outlet on top of the hull. Much easier to see the water shooting UP then OUT.
      I have thought about putting an airplane fuel filter in the water line.
      Mini Cat Racing USA
      www.minicatracingusa.com
      • Steven Vaccaro
        • 8723
        I guess not only is my "sight" going, but also my spelling. Interesting thought about a filter.
        • Simon.O.
          • Oct 2007
          • 1521
          A filter is going to be more of a problem than a solution. With a free flow system very small particles or even seeds can pass through and we will never know.
          With a filter to capture them and then block we have a problem that does not need to be there.
          A filter is used to protect a downstream component from particulate damage.
          There is no component in a FE water cooling system that needs protecting from particles, they need a flow of water.
          I do like the upwards water outlet.........sorting the K&S tube now.
