Saw this on eBay...anyone know about this hull?
Carbon Fiber Mono
Tags: None
CFK Mono 1 ( Saber ) Carbon Fiber version
[B005] $199.00
SABER (Carbon Fiber Version)
MONO 1 with Flood Chamber
Technical Data:
Length: 59 cm
Width: 16.5 cm
Weight of the Hull including Flood Chamber: ~270 Gram
CHECK OUT ETTI. WEB SIGHT..
I was just looking at one of those!! www.southriverrcboats.com (NJ) $125.00 for non carbon fiber one (Glass - like old yellers pic)...Etti...Flood chamber...Very Cool!!Comment
I am running this hull, the ETTI Saber
Pros:
stiff carbon fiber structure
flood chamber for a much more convinient ride.
Cool look
solid piano wire drive running in a carbon fiber tube. Dual bearing at the output end.
Decent build quality, the hatch fits well onto the hull body.
Cons:
Carbon fiber shields RF signal, my Saber has to have a small tail for the 2.4G antenna. My other glass fiber hulls have no visible antenna and are very reliable.
Right turn ONLY. no turn fin on left side because of the flood chamber and rudder position Left turn is painfully unstable and has large turning radius.
Long/thin piano wire has no brace, making it vibrate hardly. I add bearings inside the carbon tube to solve this issue.
Bearings always get stained and locked, need to be replaced regularly.
Tends to fly when speed reach 60+ km/h
fixed drive tube makes the prop thrust angle unchangeable.Comment
Saber from Belgium :
Axle 4mm offset
Lenght of drive outside hull : 65mm
When boat is placed on flat surface , there's 2mm " air " under the end of the drive.
btw : this is the boat in the video on the other topic about the saber.Comment
Excellent and thanks! And is the 4mm drive offset to starboard to compensate for prop walk?I let the dogs out...Comment
