Need a prop recommendation
  • sailr
    • Nov 2007
    • 6927
    I have a matrix rigger with a Nemesis 10XL (1734KV) What prop do you recommend for this setup on 4S?
    Mini Cat Racing USA
    www.minicatracingusa.com
  • HOTWATER
    • Nov 2008
    • 2323
    M445, x642...
    "Will race for cookies!"
    IMPBA D12
    My Gallery: http://forums.offshoreelectrics.com/album.php?u=1738
    • HOTWATER
      • Nov 2008
      • 2323
      Or this one......A few passes with the Dremel and you should be good to go...
      IMPBA D12
      • txboatpilot
        • Oct 2007
        • 1494
        I ran my Matrix rigger with a 9XL on 4s1p with x645 with great results.. One fast little hull if it setup right!
        Nothing like keeping you lipos warm and your prop wet!!
          • 8011
          1) How fast do you want to run
          2) How long do you want to run?
          3) What cells do you have?
          Answers to these questions are needed before meaningful answers about props can be given. If for example you want maximum speed for 2 minutes and have high-quality cells in 4S2P configuration, then a 1747 would be a good place to start. That prop takes a while to hook up but should give speeds in the low-mid-60s. If you want to run for five minutes and/or have lower-quality cells, then an x642 is a better choice. Expect speeds in the low-50s - all depending on boat setup of course.
          • sailr
            • Nov 2007
            • 6927
            4S1P 25C 5000mAh.
            Running heat races, maybe 3 minute run time.
            How fast do I want to run? Well of course as fast as possible and still be in control and able to finish the race. ;-)
            Thanks!!
            Mini Cat Racing USA
            • sailr
              • Nov 2007
              • 6927
              I never have understood the M vs X props. Is the M basically a detongued X? Is it lifting or...?
              Mini Cat Racing USA
              • sailr
                • Nov 2007
                • 6927
                ...and about a year of grinding. haaar!
                Mini Cat Racing USA
                • sailr
                  • Nov 2007
                  • 6927
                  Do you remember where you set your strut depth and angle? What about COG?
                  Mini Cat Racing USA
                  • HOTWATER
                    • Nov 2008
                    • 2323
                    sailr...I had to add that giant prop...just for you! The poor guy standing next to it proably just got done polishing it with a toothbrush!!!
                    That is a XMFTVXZ series prop!! LOL!
                    IMPBA D12
                    • HOTWATER
                      • Nov 2008
                      • 2323
                      You got it ...The M is a detounged prop (for lift).
                      Can you post some pics of your Matrix?
                      -Kent
                      IMPBA D12
                      • HOTWATER
                        • Nov 2008
                        • 2323
                        I would place your rigger on a flat board (without the turn fin, preferably) and looking at it from the side, raise or lower the strut until the tub is paralell with the board. Next, I would give the strut about a 1 or 2 degree angle back (prop angle down) just to be on the safe side.
                        The CofG should be right around where middle of the turn fin is (if it's mounted correctly). Not sure how far forward of the transom on that rigger...
                        -Kent
                        IMPBA D12
                        • sailr
                          • Nov 2007
                          • 6927
                          I'll try to get some pics of it tomorrow.
                          -Kent
                          Mini Cat Racing USA
