How To
  • TRUCKPULL
    • 2975
    How To
    How would you hookup a water line from a house tap to a 5/32" water line in a boat to test for leaks??
    Larry
  • Steven Vaccaro
    • 8723
    This is how I did it.
    http://www.offshoreelectrics.com/inf...tem-tester.php
    • B-DAWG
      • Apr 2009
      • 42
      I just use a syringe like the one you use to inject a turkey with.
      • j.m.
        • Jul 2008
        • 838
        You could probably also figure a way to fit some fuel tubing and a water balloon adapter together...
        • TRUCKPULL
          • 2975
          I have a brass garden hose end that you use to repair a garden hose.
          Does the Epoxy stick to the Water/Fuel line??
          Larry
          • FE Wannabe
            • Jul 2007
            • 626
            If you want to connect to an outside hose bib you could use one of these:
            They should be available at any Home Depot as well, in the drip irrigaton section.
            I used one of these and it works great, just becareful with the water pressure, because you can generate a lot more PSI than your boat will ever see in the water. You don't want to blow out the O-rings in your cooling can.
            The nice thing is that if it doesn't leak with the house water pressure, you can be sure it won't leak when you are running it at the lake.
            Brad
            SoCal Fast Electrics|H&M Drifter S-CC1512/4S/T180A|Aeromarine Scorpion 32"- UL-1/4S/HM200A|Insane 34- CC1515 1Y/4S2P/T180A|BK Bandit S-CC1515 1Y/4S2P/T180A|Insane FE30 UL-1/4S/ETTI 150
            • sjslhill
              • 1513
              Hey Larry!
              How it goes Larry! How have you been?
              thanks,
              Steve
              Larry
              • FRED
                • Jul 2007
                • 233
                how to
                Gentleman has enough info!
