DF 29 setup
  • knpc
    • 566
    DF 29 setup
    Here's a bit off the backstory. My brother and I were racing as only brothers would do, trading a bit of paint. His SV didn't finish the race, cracked hull. So I got him a df29 and put all of his components in it. He loves the handling now but wants a bit more speed than the sv motor and esc can provide. The boat will run on 4s. There is a 10xl in the swap shop I was thinking about. What esc would he need for it? Would this be a good setup or is the something else I should consider. I think he would be happy if it went 40mph or so.
    Keep in mind he is a cheap sob.
    Thanks
    Kevin
    Rico 29, Sprintcat 34, Insane FE 30 Hydro, 43'' Aeromarine Conquest
  • Rumdog
    • 6453
    The 10xl will get you 40mph easy. I'd get at least a 120 amp esc. You can find good cheapos on ebay, such as the Hobbywing Seaking esc's.
    • tth
      • Apr 2008
      • 1510
      I would go with an 8xl in the 29" hull. Its what I have in mine, she flies and handles like a charm. A Hydra 120 or Etti 150 will do the trick. Good luck.
      • ozzie-crawl
        • Sep 2008
        • 2865
        i run a 33" with a 9xl 447/3 prop
        with a 29" i would definitely run a 8xl
        • Heath M
          • Mar 2008
          • 806
          8xl hydra120 and a x440/3 or m442 will be a good race setup
          Heath
          Brisbane,QLD, Aussie
          • knpc
            • 566
            Thanks for the help. Which would be the better sport motor on 4s 8xl,9xl,10xl ? Longer runtimes and a reliable setup would be more important than gaining a few mph. I run a 9xl in my 29'' mono with speeds in the mid to upper 40s, but things do heat up after 4-5 min. He is used to run times of 10 min with his sv, not sure if thats possible with one one of these setups or not.
