TC31 brushless
  • wickedgmc
    • Jun 2007
    • 719
    sorry wrong numbers they are 20c constant and 30c sustained, I was talking about the cell count they are 2s2p, would I run 2 of them in parallel or series?
    • steveo
      • 1454
      those sound like good numbers who makes them, series should be fine with those numbers if your going to be the pushing the limits then yes parallel
      • steveo
        • 1454
        series the voltage is additive
        parallel the amps/runtime is additive
        it would be more effeicent to run a higher cell count in that boat
        • wickedgmc
          • Jun 2007
          • 719
          that is a pair of maxamps that I have for my emaxx, I also have a set of the Orion 3200's and a set of the Orion 4800's
          • steveo
            • 1454
            do you know what setup yor going to use yet like 12 or 18 cells, i would not recomend running different lipo companies together , two orions and a maxx amp to get 18 cells,
            rough estimate
            10/11xl 33mph-12 cells
            13/14xl 38mph-18cells
            • wickedgmc
              • Jun 2007
              • 719
              it will be either a pair of lipos or 4 of the same lipos
              • wickedgmc
                • Jun 2007
                • 719
                I got the parts from OSE today and have pretty much completed what I have. Need to buy some epoxy to epoxy the motor mount to the boat and that will be that.
                Still need an esc and want to buy it here but they are out, anyone know of any other source for the hydra 120?
                • wickedgmc
                  • Jun 2007
                  • 719
                  any suggestions for epoxy will regular old JB weld work or is there something better?
                  So I see the hydra 240 is in stock, will this work and just be overkill or will it just not work with my setup?
                  • saleens7
                    • 1108
                    it will work and be overkill...
                    • saleens7
                      • 1108
                      JB weld holds stronger than epoxy does...i dont know, but 2 ton devcon might be stonger....but JB will be good enough
                      • wickedgmc
                        • Jun 2007
                        • 719
                        sometimes my lack of patience costs me money, overkill is not always a bad thing! LOL :D
                        • wickedgmc
                          • Jun 2007
                          • 719
                          #27
                          First I need to say thanks to Steve and OSE, I ordered the esc and some other stuff on Wednesday and it just got here, now I can run my boat tomorrow!!!
                          This ESC is a monster, I do have a question though, is it waterproof? Wont be able to run too long tomorrow I have no water jacket for the motor, but I will be able to run and see how it does.
                          Thanks for all the help and advice and I will let you know tomorrow.
                          • NorthernBoater
                            • 811
                            #28
                            It is waterproof.
                            • wickedgmc
                              • Jun 2007
                              • 719
                              #29
                              ok some more questions,
                              1. the hydra 240 has 2 red wires for power and 2 black wires for power, can I use 1 connector and combine the 2 red and 2 black to there respective poles one connector or do I need to use 2 connectors?
                              2. difference between parallel and series? My thoughts are if I run 2 2s2p lipos in series I will increase run time and still provide the same 7.4 voltage to the esc and if I run the same in a parallel I will send 14v to the esc? Does that make sense to anyone else? Or am I just way off
                              thanks
                              here is a few pics of the almost finished boat
                              • wickedgmc
                                • Jun 2007
                                • 719
                                #30
                                So I took it out it worked pretty darn good so far. Got up on a plane easily but was not as fast as I expected.
                                Hydra 240
                                Feigao 12xl
                                2 Max amps 2S2P 7.4 cells
                                The Hydra has 2 sets of power wires and I was wondering if anyone has put them together so you could parallel a set of batts?
