Mixing brands of Lipos
  • midwestboat
    • Feb 2009
    • 56
    Is there a problem with doing that? Will it affect longevity of the lipo's
  • Boatman
    • Jan 2008
    • 796
    That is tough. If running in parallel in my opinion you are perfectly safe as long as you leave room and aren't pulling 100A from 100A packs. Running them in series may result in shorter life out of one pack. It is okay to do but keep an eye how many mah you are putting back. Also as long as they are rated nearly identical it is most likely safe. Could be the same cells anyway depending on brand.
    • midwestboat
      • Feb 2009
      • 56
      Thanks, I figured I would run 2 of the same brand on the one side and 2 of the other brand on the other side.
      • Jeff Wohlt
        • Jan 2008
        • 2716
        They should be the same mah. Also, no 10C vs 20 C mix.
        www.rcraceboat.com
        jwohlt5362@yahoo.com
