motor question
  • Rex R
    • 992
    motor question
    anyone know what size airplane prop I can safely run with a feigao 540s 8t motor (2s2p) for an air boat? thanks
    rex
  • Diegoboy
    • Mar 2007
    • 7244
    I will assume direct drive to the prop, correct?
    • Rex R
      • 992
      that is correct. I was planning to keep things simple, just 'bolt' the airscrew propellor to the shaft.
      • Diegoboy
        • Mar 2007
        • 7244
        Rex,
        I'm no expert on airplane props, but maybe you should work it the other way around. Get the hull (size and weight) then choose a prop that will fit the boat, then find a motor that will turn it.
        Here's an RC airboat forum that may be able to help you better with that question.
        • sailr
          • Nov 2007
          • 6927
          About a 6 x 5 would be MAX. Inrunner's have no torque, only high RPM. Check your temps really well! You would be MUCH better off getting an outrunner motor! Tell me more about the airboat. Length, width, weight, etc. and I'll make a recommendation to you.
          Mini Cat Racing USA
          www.minicatracingusa.com
          • Rex R
            • 992
            projected length & width 24"l, 14"w, weight ???.(still on the drawing board ). will be mostly foam, balsa, and thin ply.
            (grin) found that forum tother nite .
            • Rex R
              • 992
              after due consideration (and info, thanks F) I decided that I'll try something a bit smaller like this http://www3.towerhobbies.com/cgi-bin...?&I=LXE383&P=7 instead.
              • sailr
                • Nov 2007
                • 6927
                You could get a 22mm-28mm outrunner motor that will swing a 6" prop. It would be a rocket on 3S 1000mAh-1500mAh battery and about a 20-25A esc.
                Mini Cat Racing USA
                • sailr
                  • Nov 2007
                  • 6927
                  This a REALLY small airboat. I'd encourage something bigger. http://www3.towerhobbies.com/cgi-bin...?&I=LXE385&P=7 . but you'd want to go up to a 35mm outrunner.
                  Mini Cat Racing USA
                  • sailr
                    • Nov 2007
                    • 6927
                    I'd like to have one of these without the nitro engine! http://www3.towerhobbies.com/cgi-bin...=LXURN3**&P=ML
                    Mini Cat Racing USA
