Propeller work
  • Jimmy Sterling
    • Apr 2008
    • 393
    Propeller work
    I have recently started modifying my own propellers and would like to know if someone could enlighten me as to the most effective way to actually 'thin' the blade out. Any tips are greatly appreciated.
    If using a dremel stone or similar, what shape ?
    Jimmy
    Come to the FASST side
  • AndyKunz
    • Sep 2008
    • 1437
    I always used a flat file.
    Andy
    Spektrum Development Team
    • egneg
      • 4670
      I use a 1" belt sander with 120 grit. You need to have a light touch and smooth movement for this method to work.
      IMPBA 20481S D-12
      • andym
        More Go Than Show Prop Co
        • 2406
        I use the belt sander as above and a 90 deg air die grinder with pads similar to tough scotch bright to finish, more control than the belt sander. Edge cup seems to improve alot of props but have a few that rolling the blade does even better
        • Scott T
          • Oct 2007
          • 590
          Jimmy
          I buy them already done!
          But I have thinned blades using files and 120 grit sandpaper (using progressively finer paper to finish). I've found a points file works really well, they small so they get into all the tight spots, but tough enough to do a good job.
          We can have a chat on Sunday if you like Jimmy.
          Scott Tapsall
          Pine Rivers Model Powerboat Club - Facebook Page
          My Gallery
