Fine Design Racing
EX President of the Offshore FE Vultures SocietyComment
Midwest-
What exactly do you not like about this boat? Lack of speed? Runtime? Ride attitude?
You've got good equipment...just need to figure out why you're unhappy.
The 5S Lipo packs you have should be wired in series to the ESC. That would make for a 10S 1P setup. You can really only use approximately 3800 to 4000 mah's out of a 1P setup, so your runtime will be short. 3 minutes or less depending on your amp draw.
Chris sending you 2 more packs leads me to believe that he's setting you up for a 10S 2P setup, which will keep the voltage the same as now, but double the battery capacity to the motor...in essence doubling your runtime. But still, probably 5 minutes max, and that's after alot of testing.Comment
FWIW-many of us want to help you with this so you don't end up choking on the bite you took by going with a 10S setup as your first FE boat. It's not the normal or easy way to get into FE and can be/is flat out frustrating. I'm glad you found this board-the people here will help you get it sorted out. Your experience with gas will definitely help, but you've still got a lot of homework ahead of you.
Bloomington H.S. Class of '88!Comment
Midwest-
Are you in Bloomington Still?Comment
If Chris Fine said 15 minutes on your setup take him to court, as I can not believe he would make that comment
DouggieComment
What is a honest run time I should expect with the current setup? What should I expect when adding 2 more 5S lipo's? What can I do to get more run time and pick up speed? Bigger controller? Bigger Motor? More Lipo's? not possible? Thanks.Comment
SCALE BOATS: Tugs, warships, fishing trawlers, utility boats, etc..."A quick temper will make a fool of you soon enough."
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Bruce Lee. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Comment
For the record, the scale boats he's referring to are most likely not going the speeds you are talking about. But I could be wrong.IMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
