Paint??
  • jingalls007
    • 1015
    Paint??
    Does anyone have any suggestions from start to finish for painting a boat? Including type of paint that works best? thanks
  • detox
    • Jun 2008
    • 2318
    Double post.
    • detox
      • Jun 2008
      • 2318
      Clean boats surface then scuff boats surface using Norton Gray 000 fine synthetic wool pads (Homedepot sells them). Prime surface using regular Krylon primer. Scuff primer using these same 000 fine pads. Then paint using Regular Krylon paint(Homedepot or Wlamart sell it). I always try to spray outdoors when the weather is good, no wind, low humidity, and plenty of light to see by.
      • LST XXL
        • May 2009
        • 79
        do you have some links to this paint..my boat was never painted..it is still just the plastic..what would i need to do?
        if it ain't broke you ain't trying hard enough.
        if at first you don't sucsed maby failure is you thing.
        • detox
          • Jun 2008
          • 2318
          Walmart, Homedepot, Ace Hardware, etc. sells this very common Krylon paint. If the surface is very smooth like most Gel coats all you need to do is clean the surface using denatured alcohal, then scuff, prime, then paint.
          • bustitup
            • Aug 2008
            • 3071
            no clear coat?
            • chunkymonkey28
              • Apr 2009
              • 58
              I just used primer, paint, and clear coat from my hardware store ( not RC brand stuff) and it worked well on my ABS hull.
              • detox
                • Jun 2008
                • 2318
                Originally posted by bustitup
                no clear coat?
                Scuff color coat using Gray 000 pads before applying Krylon clear coat. The 000 pads work LOTS EASIER than sandpaper.
                • jingalls007
                  • 1015
                  anyone use this stuff on fiberglass? http://www.krylon.com/products/fusion_for_plastic/
                  It's specific use is for plastic however is SUPPOSED to be good for fiberglass as well, just wanted to see if anyone has tried this before i get to paintn'.. thx
                  • egneg
                    • 4670
                    I have used it with good results. The red and white were done with Krylon Fusion.
                    Edit: I forgot to add that I used an automotive clear after the artwork and a bearier coat.
                    IMPBA 20481S D-12
                    • bustitup
                      • Aug 2008
                      • 3071
                      I'm building a blak gel coat boat ....means I won't have a black windshield......so i'm thinking of chrome for my windshield
                      Krylon have chrome? If so any good or any suggestion?
                      • jingalls007
                        • 1015
                        did the Fusion "need" a clear coat do you think? Krylon claims that it doesn't need a clear coat.
                        • egneg
                          • 4670
                          Alsa has a product but it is a bit costly for what you want as one spray bomb is about $40.00 usd.
                          IMPBA 20481S D-12
                          • egneg
                            • 4670
                            No but the paint I used for the other artwork did. I also have to say that the clear did add quite a bit of depth to the overall paint job.
                            IMPBA 20481S D-12
                            • jingalls007
                              • 1015
                              I am actually debating the same question right now and was tossing around the idea of using Mirrored Auto Tint as a windshield instead of chrome paint.
