1.1M Cat setup help
  • Jeff Wohlt
    • Jan 2008
    • 2716
    I would stay with 6S. Yes but it has the mass to spin a decent prop without loading the motor very much I think it would be a good set up. You can run 4 or 5S to start with but it does say 6S. Looks like a well built motor for a cheapo. Screwed in rear plate, etc. Numbers are not that bad either.
    Not sure anyone had seen these. I owuld have said KB 45 but they seem to be big amp hogs.
    www.rcraceboat.com
    [email protected]
      • 9488
      6s I think will be to much on a 2000kv motor in a big boat?
      44,000rpm
      • Himalaya
        • Apr 2009
        • 251
        I personally prefer inrunners, for :
        the conviniency to get it water cooled
        much faster throttle response than an outrunner having similar power capability
        much higher RPM capability, wider KV choices available.
        much thinner motor diameter, results in less bend angle to the flex cable and stuffing tube and thus higher drive train efficiency.
        • Ub Hauled
          • Aug 2007
          • 3031
          Originally posted by Jeff Wohlt
          Here...if you want some meat and muscle. Well built and 6S on each would be great. I would not hesitate to push it to 8S either.
          This is what I would use for big hulls. You need the mass of 44mm dia. Shaft is already reduced.
          http://cgi.ebay.com/Large-B44-2000KV...QQcmdZViewItem
          Jeff, that seems to be a nice find... thanks for posting.
          • Simon.O.
            • Oct 2007
            • 1521
            1.1m is close enough to 115cm which by a stroke of good luck is the length of the HPR 115.
            Have a look here for some power ideas
            http://forums.offshoreelectrics.com/...ead.php?t=7899
            I'll help if I can.
            • norbique
              • May 2009
              • 356
              Hi! Thank you all for your relpy!
              What do you think about using two of these motors in the cat?
              or this one, it's quite similar to what Jeff Wohlt suggested on ebay:
              Simon, I hear others saying you're an expert in scratch building.
              I want to ask you what do you think/recommend what would be the best way to reinforce the balsa cat?
              I am planning to plank hull with 2mm balsa first, then ontop of that plank again with 0.4-0.8mm birch ply. Would this suffice for this huge boat or should I even add fiberglass to the outside/inside of the hull? Glassing the inside would be much more difficult though...
              Thanks!
              Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.
              - Mark Twain
              • EPower
                Banned
                • 391
                Thanks!
                I use KB45 motors they are great,Amp hoggers for sure but with the right prop & esc they will work fine
                they are not in stock at the moment and the ETA from hobbycity is 8 to 10 weeks LOL
                Adrian
                • norbique
                  • May 2009
                  • 356
                  #23
                  Thanks Adrian!
                  By amp hog, you mean it needs a higher amp ESC than other motors would? Less efficient?
                  Would a 100A watercooled ESC be enough for the KB45-10L 1800kv on 6S2P A123?
                  And what ESC for the KB45-08L 2300kv with 4S or 5S batts?
                  - Mark Twain
                  • Simon.O.
                    • Oct 2007
                    • 1521
                    #24
                    Thanks!
                    Expert ?? Just an enthusiast.
                    2mm balsa may be sufficient if you have small frame spacing and stringers.
                    For a hull bottom I would go with 3mm and cover with 1mm ply expoxied on. this will be very strong. i would suggest that it would be stronger and stiffer than a lot of glass hulls.
                    My new 30" has 3mm bottom without ply skin but as with the 4S rigger it will get a lot of varnish laid on.
                    Ply and epoxy are expensive for me to use on hulls so that is why I use more balsa and varnish.
                    Some of my work
                    http://forums.offshoreelectrics.com/...ead.php?t=8008
                    and some reading.
                    http://forums.offshoreelectrics.com/...ead.php?t=7494
                    Enjoy.
                    • EPower
                      Banned
                      • 391
                      #25
                      Thanks Adrian!
                      they do draw allot of amps i blew a TURNIGY Sentilon100A HV on the second run on 6s brought an Etti 150 race blew the capacitors on it i had it replaced and had the capacitor module fitted to it and so far so good
                      on the KB45-08L 2300kv 4s would be the max i would run,and start with small props x442 or similar these motors are rated at over 3000 watts
                      I have to say that i do push these motors to their limit but then they are cheep to replace
                      i gave my boat a short run about one minutelast Sunday with my new Hyperion 5500mAh/35C batt and could really feel the difference in power we will see how the motor & Esc will cope with 3 minutes runs
                      what esc did you want to run in it?
                      Adrian
                      • norbique
                        • May 2009
                        • 356
                        #26
                        Adrian,
                        I was thinking of the TURNIGY Sentilon100A HV, but replace the caps for super low ESR ones with higher capacity asap Yes, good batteries are a must. I have some A123s and they're amazing. I will use only use those in my future projects. No lipo fires, not even the thought in the back of my head it might happen anytime.
                        A KB45-10L 1800kv on 6S2P A123 is what I am thinking about. But I don't know will the Turnigy hold up. I'd rather go for a lower KV motor and go up with the volts.
                        Simon,
                        Thanks again for your help. I was to use 2mm balsa on the bottom too, but I'll listen to you and use 3mm on the bottom and 2mm elsewhere. Also I will use 0.8mm ply on the bottom and 0.4mm ply everywhere else epoxied. I can buy the ply at relatively good price.
                        EDIT: Thanks for the balsa build thread link. Now I'm afraid All my bulkheads are from 5mm hard balsa. Except for the last one where the shafts will go through, that one is 5mm ply.
                        I must build my boats extra strong, but not only because of speed. Last weekend I ran across a bough floating on the surface of the water with my Hydromite. It threw the little boat half a meter out of the water. Luckily I only bent the turn fin, nothing else was damaged.
                        - Mark Twain
                        • EPower
                          Banned
                          • 391
                          #27
                          Adrian,
                          Simon,
                          You don't really have to replace the ones on your esc just add some to your batt wires and try to keep them as close as possible to the esc side of the batt wires have a look at the picture
                          Adrian
                          • norbique
                            • May 2009
                            • 356
                            #28
                            I mentioned replacing the ones in there since I'm going to disassemble it to add water cooling anyway. But your setup is easy to make, thank you, I'll consider it!
                            - Mark Twain
                            • crabstick
                              • Jul 2008
                              • 954
                              #29
                              Hi Norbique,
                              For your build I would recommend thin ply!! it will last a lot longer. there is a lot of load on the hull and hardware at 100k and can bend rudders and struts if they are not up to the job. I have recently finished building a 35 inch cat with ply after my previous balsa cat self destructed on a blowover... sure its heavier, but I have a lot more confidence in the strength of the boat.Ply is pretty easy to work with as long as you have a steady hand, a sharp hobby knife and a steel ruler.
                              From the examples I have seen and read about IMO a 40 inch'ish light twin 8xls on 4s each should be able to reach that 100k for sport or SAW runs.
                              The KB45 8L is a motor I am curious about and if it goes as good as the specs it might be another option, they are a bit heavier than the 540xls. power to weight to consider, also load on the hull.
                              IMO I think you may have to purpose design the hull, with minimal lift in the tunnel, because as the boat goes faster and faster more lift is obviously provided from the larger volume of air passing through the tunnel and then over she blows!!! lol we dont want that
                              for batteries if you dont want to spend a squillion, these could be an option
                              run 2p to each esc.. Obviously get the best packs you can afford, but if you are on a budget, these might be the ones to get.
                              I have recently got some of these and am finding them good so far, they were 40degC after running my cat today and all cells were within .02 of a volt per cell of balance after running. Setup was the KB45 8xl on 4s2p for about 4 mins on m447, speed is around 70kmh in calm water, All in all im not too happy with the KB on 4s at the moment, I might get the 8L and try it. So duee to my findings I would NOT recommend the KB45 8xl for 4s, they are just too low in KV and you have to run giant props.
                              Those motors Jeff posted the links to look the same size as a kb45, but has detachable endbell by the looks! wonder what it goes like
                              For the Caps - checkout Shultze's website, theres a howto there
                              Cheers!
                              Matt.
                              FE, Nitro and Gas racing in Auckland
                              www.rcboats.co.nz
                              • EPower
                                Banned
                                • 391
                                #30
                                Originally posted by crabstick
                                Hi Norbique,
                                Cheers!
                                4s for that motor is not enough juce m8 i have some 6s 4500 mah zippys you can have, might not be able to handle the power LOL
