I picked up a Hextronik HXT120 ESC to replace the toasted stock ESC in my Blackjack 26. Having a few issues and had some questions regarding programming. My setup is the stock BJ26 motor, HXT120 ESC, and 5S (a 2S pack and a 3S pack in series). I am hoping that somebody here has a little experience with this ESC or similar. Here are my issues and questions...
Issue 1 - Cannot get my computer to recognize the ESC when plugged in with the USB connector. I downloaded the software from Hextronik but when I plug in the USB connector I get an error message that the drivers cannot be found (even though they installed with the software). The ESC is never recognized in the Hextronik software and says "disconnected". I tried installing this on a computer running Vista. Could that be the problem perhaps? Any other suggestions?
Question 1 - What should I set the low voltage cutoff at for this setup? Here are the available settings...
4.8V Cutoff Voltage
5.6 V Cutoff Voltage
6.0 V Cutoff Voltage
7.2 V Cutoff Voltage
8.4 V Cutoff Voltage
9.0 V Cutoff Voltage
11.2 V Cutoff Voltage
12.0 V Cutoff Voltage
14.0V Cutoff Voltage
15.0V Cutoff Voltage
16.8V Cutoff Voltage
18.0V Cutoff Voltage
Question 2 - What should I set the timing at for my setup? Here are the available settings...
4 -10 degrees 12 or more pole motor or outrunner motor
10 - 20 degrees 6 or 8 pole motor
20 - 30 degrees 2 or 4 pole motor
Thanks in advance for any help you guys can provide. I am kind of a noob at this stuff
4.8V Cutoff Voltage
