NAMBA rule question
  • sjslhill
    • 1513
    NAMBA rule question
    AquaCraft UL-1 Superior, can you run A123 packs? If so, how many cells, 4? Is this a 1P class or is 2P allowed? The same with SV27?
    Not saying that I would not run LiPoly, just curious.
    Steven is working on me real hard to go to MI for the Nats.
    thanks,
    Steve
  • Ub Hauled
    • Aug 2007
    • 3031
    There isn't a class for the UL as it comes in NAMBA... you'd have to change back to a 700 can and NiMh (14.4v). You could use A123 cells, with the equivalent of a of 14.8v max and 10,000mAh total.
    • sjslhill
      • 1513
      I thought the UL-1 was the LSH class boat? scratching head And I thought the LSO was the SV-27. Is it the motor package or what exactly? Or maybe these are local rules that I am thinking about. 700? I thought those were voted out in NAMBA but the IMPBA still had them. I have a 700 in a classic hydro now.
      • sjslhill
        • 1513
        Well, I went to the rules section and it's totally different that I thought.....
        Where did I get the idea that the Aqua Craft drive packages were in the rules for classes, is that local events?
        • Boatman
          • Jan 2008
          • 796
          exactly, clubs are "allowing" that drive combo.
          • sjslhill
            • 1513
            Nevermind...I see the rules now from the MMEU site 2009 N.A.M.B.A. FE Nationals
            LSO= ** NAMBA LSO accept 4s1p Lipo allowed
            additional motors allowed Aquacraft SV27, ProBoat Black Jack, and AC UL1 motor
            LSH=*** NAMBA LSH accept 4s1p Lipo allowed
            OPC=*Motor options Aquacraft sv27,Proboat Blackjack,and AC UL-1 motor
            4s1p lipo.
            • sjslhill
              • 1513
              other questions
              what is Production? Ult Offshore, Ult Sprint, N2 Sport (hydro?)
              • sjslhill
                • 1513
                • Bill-SOCAL
                  • Nov 2007
                  • 1404
                  A123 cells have proven themselves in other RC applications. However, for boats they are not as neat a solution as lipos are.
                  They are rated at 3.3 volts per cell nominal. So a 4 cell pack is 13.2 volts and 5 cells are 16.5 volts. A 5 cell configuration is too high for "P" power so you would be stuck with a 4 cell pack at 13.2 volts.
                  Capacity is the second issue. The largest cells are 2300 mAh, so to get enough for a decent heat run you would need to run them at 4S2P to get a 13.2 volt pack with 4600 mAh capacity. The cells are pretty large and I doubt you could fit them in many boats.
                  Don't get me started
                  • Darin Jordan
                    • 8335
                    However... if you CAN fit them in... the UL1 NEEDs the weight in the nose... from what I've seen...
                    Darin E. Jordan - Renton, WA
                    • sjslhill
                      • 1513
                      thanks
                      Thanks Bill, I understand the limitations of A123 but since I have hundreds and that's what we sell for many applications, I figured that's what I would use. 4 fully charged LiPoly cells is 16.8V but 5 fully charged is 18V. However, at 2.3AH the voltage drop and weight disadvantage would offset a 5000mah LiPoly pack. The rules in my opinion should allow for 5 A123 cells in series but that's not going to happen. I'll stop at right there.
                      Anything thoughts on the those classes I had listed?
                      thanks,
                      Steve
