Mixed mAh lipos OK?
  • Tony
    • 413
    Mixed mAh lipos OK?
    Hi guys.
    Will two lipo packs with diff. mAh work in series ?
    7.4v 3300mAh 25C and 7.4v 4000mAh 25C
  • Doby
    KANADA RULES!
    • 7280
    No.
    Grand River Marine Modellers
    • ED66677
      • 1300
      NO...
      and YES but...
      having two different capacity in serie will cause some problem, the smaller capacity pack will be overdischarged before the ESC cut-off acts, this will kill the pack!!!
      the rule is to always have same capacity pack, no matter if they are connected in serie or parallel!
      Emmanuel
      • bustitup
        • Aug 2008
        • 3071
        NO
        it might work for a bit but something is going to fail
        • Doby
          KANADA RULES!
          • 7280
          No, ,,,,,,,What Ed said!
          The lower capacity pack will not survive for long.
          • Tony
            • 413
            I'll just have to buy another 3300mAh lipo to run with the pack i have now. My other TP pack wouldn't charge correctly due to "wrong polarity, and wrong voltage" .... Anyways, thanks for the info guys. e"
            • Flying Scotsman
              Fast Electric Adict!
              • Jun 2007
              • 5190
              Just , a note you can run different Mah packs in PARALLEL. There was a discussion on this very subject on another forum and Professor Bill-SOCAL weighed in and stated Ohms law.
              Douggie
              • Himalaya
                • Apr 2009
                • 251
                That is correct, run different mAh packs in parrallel has no issue, as long as the S numbers are same, and the discharge capability(C rating) better be close. I run 2600mAh and 2200mAh 6S packs in parallel without a single problem.
                • Tony
                  • 413
                  So, parallel = more run times and less speed
                  series = more speed and less run times
                  correct?
                  • Flying Scotsman
                    • Jun 2007
                    • 5190
                    correct?
                    It comes down to volts and amps
                    2 2S1P 2500 mah 20C in parallel= 7.4v 5000 mah
                    2 2S1P 2500 mah 20 C in series = 14.8v 2500 mah
                    Douggie
                    • Ocean Racer
                      • Sep 2007
                      • 502
                      Dougie maybe Im missing something but did you forget to change something on your chart?
                      Failure is the First step to SUCCESS
                      • bwells
                        • Jan 2009
                        • 842
                        I'll bite! The C rating would change on the parallel example, yeah?
                        • Himalaya
                          • Apr 2009
                          • 251
                          Douggie is right, C is a constant showing how well the pack handles high current, never changes unless it's getting old.
                          Let me continue Douggie's equations:
                          2 2S1P 2500 mah 20C in parallel= 7.4v 5000 mah 20C, good for 100A*7V =1400W
                          2 2S1P 2500 mah 20 C in series = 14.8v 2500 mah 20C, good for 50A*14V = 1400W
                          make sense ?
                          • Tony
                            • 413
                            make sense ?
                            2 2s1p 7.4v 5000mAh 20C in series = 14.8v 5000mAh 20C, good for 100A*
                            Is 100A* good for a 32" cat running a 9xl, ETTI 125 esc, x642 prop?
