Assan Hack 2.4Ghz module
  • RPC1
    • Apr 2008
    • 112
    Anyone ever use one of these?
    http://www.hobbycity.com/hobbycity/s...dule_(PPM_Only)
    http://www.hobbycity.com/hobbycity/s...(Short_Antenna)
  • Meniscus
    Refuse the box exists!
    • Jul 2008
    • 3225
    If you do a Google search, I seem to remember that there are some detail reviews for this item online that you can review.
    • RPC1
      • Apr 2008
      • 112
      I was just wondering if someone has used one in a marine environment with a pistol radio. Thanks.
      • SweetAccord
        Speed Passion
        • Oct 2007
        • 1302
        I have seen it used by a guy at my local lake. Guy used a Futaba 2PL AM radio and it works great.
        • M.M.
          • May 2009
          • 264
          Didn't you??
          http://forums.offshoreelectrics.com/...ead.php?t=8253
          • bigwaveohs
            • May 2009
            • 535
            Or you could just get a Tactic 2.4 Ghz. from Tower and spend less for the whole Tx/Rx package!
            Tower Hobbies carries an expansive collection of RC cars, RC airplanes, RC boats, model trains, sot cars, and supplies for all hobbyists.
            I let the dogs out...
            • SweetAccord
              Speed Passion
              • Oct 2007
              • 1302
              Assan Hack:
              Pluses:
              1. The receivers are only about 24.50 as is the Tactic, but the Assan one is really thin.
              2. You get to keep your radio so if its a digital AM or FM you get to use all the features instead of loosing all the features to get into a 2.4 and only have a few controls like the Tactic.
              3. You don't end up with another radio if you already have a FM or AM radio and you do the hack instead.
              4. Assan is very solid and reliable.
              Negatives:
              1. Assan may only be purchased overseas (currently).
              2. You lose the warranty of the radio from the manufacturer with the hack.
              3. The receivers and hack module is hard to get.
              4. The Assan recievers only work with the Assan modules.
              5. Cheaper than any FAAST system.
              The choice is yours.
              Peace~
              • RPC1
                • Apr 2008
                • 112
                Originally posted by M.M.
                Yes I did, after this thread was started. So far it has worked flawlessly.
                • M.M.
                  • May 2009
                  • 264
                  Oh, my bad. I didn't realize that this was an old thread
                  • bigwaveohs
                    • May 2009
                    • 535
                    Originally posted by SweetAccord
                    Assan Hack:
                    Pluses:
                    Negatives:
                    Peace~
                    extra receivers were $17 at Tower...
                    • SweetAccord
                      Speed Passion
                      • Oct 2007
                      • 1302
                      Which ones? Post link, I have not seen them.
                      • bigwaveohs
                        • May 2009
                        • 535
                        It was posted on 6-11-09 on this forum...scroll down.
                        • SweetAccord
                          Speed Passion
                          • Oct 2007
                          • 1302
                          I converted all my FM to the Assan's. There is a strong following of people that have used all the other 2.4ghz systems and love this just as well.
                          See here: http://www.rcgroups.com/forums/showthread.php?t=723343
                          I find they work great, no range or glitch issues and the long antenna problem is resolved also. The receivers are smaller than anything on the market hands down! The one posted by Doggett are small but there is a smaller one that I use. The 4 channel X8 R4 Size: 36 X 14 X 3mm (1.97 X 1.02 X 0.39 inch) Weight: 3.2g.
                          The X8D works great on pistol type radios. On a Futaba 3PM 75MHz radio the X8D fits as if was made for it. No modification to the antenna mount was needed. All you need is to find a spot where you want to install the X8D as there is plenty of room in the Futaba's radios.
                          Radio install of X8D: There are 3 lines grouped together on the break out board that you need to look for:
                          VDD (Futaba) = Power goes to Assan +
                          SIG (Futaba) = Signal line to Assan (PPM)
                          G (Futaba) = Ground to Assan
                          All the other lines which are HRS/PPM, CR, Data, RF-SW and Ant are to be unsoldered; place a long piece of shrink tubing over them and pack away as they are not used. The board is also removed as it's held by 3 screws.
                          Pics:
                          http://cid-ace3bbbe72a55299.skydriv...IMG%7C_0849.JPG
                          http://cid-ace3bbbe72a55299.skydriv...IMG%7C_0850.JPG
                          http://cid-ace3bbbe72a55299.skydriv...IMG%7C_0851.JPG
                          http://cid-ace3bbbe72a55299.skydriv...IMG%7C_0852.JPG
                          Also it was confirmed by Futaba that the 3PM 9.6v system WILL operate up to 12v and if a 11.1v lipo is used it will not void the warranty and will operate properly even to 12.1 volts. I also learned today that the X8D will work fine with the 11.1v lipo battery.
                          Hope that helps.
                          • SweetAccord
                            Speed Passion
                            • Oct 2007
                            • 1302
                            Continuing topic on the ASSAN:
                            http://forums.offshoreelectrics.com/...ighlight=assan
