I have recently heard about a gross misunderstanding of the function of the sleeve bushings used in R/C boats. Some seem to believe that they are bearings that must be attached to the strut or stinger to hold oil and grease. Some even suggest putting solder on the bushings to keep them from rotating. This is simply wrong and gives away some of the advantages of the sleeve bushing.
These were developed years ago by nitro racers to reduce drag and play in their struts. The then-common lead/teflon bearings worked but their size was not very uniform and they quickly developed excess radial play due to their softness. Lead/teflon really works for 'slow' boats - full scale and models - but is pretty poor for high rpm/high load bearing use.
The solution was to use two nesting sizes of brass tubing. These are dimensionally uniform with just the right amount of play to avoid galling. The stuffing tube is commonly 0.25" brass tube, which allows the sleeve bushing for a 3/16" shaft to slide in perfectly. The holes in the bushing allow oil or grease to travel to both sides of the bushing. Why is that important? Because when the prop shaft is rotating the bushing rotates too and both sides need lubrication. This reduces friction by reducing the relative rpm of the surfaces - more power to the prop. Wear is also reduced - I have never replaced a sleeve bushing due to wear, and I've been running them for over seven years in most of my models.
In my UL-1 the original bushing was stuck in the stuffing tube and didn't rotate. I pulled it out and gently sanded it with 600 grit paper until it slid in easily, then polished it with 1500 grit paper (from the auto parts paint store). Now it works great, as designed.
Bottom line - use the sleeve bushings the way they were designed. They work, and very well too - I've set quite a few FE SAW records with them, as have many of the nitro guys. Whatever you do, don't glue or solder them into the stuffing tube!
Ths photo shows one 3/16" bushing I have used in three heats each month for a year. I can't find a dimensional change with a micrometer, it still works just fine. The 1/4" stuffing tube slides into the strut, and the bushing slides into the stuffing tube. I prefer gear oil, but others use grease with good results.
