need ideas on watercooling cuda 125
  • 6S HYDRO
    • 1320
    i need some ideas or previous methods of watercooling a cc baracuda 125 speedo
  • NorthernBoater
    • 811
    I believe this is what you are looking for.
    http://www.offshoreelectrics.com/pro...prod=etti-a044
    • 6S HYDRO
      • 1320
      wouldnt that only cool one board of the esc when theres 3, or can i separate them and put in 3 of those.
      • DISAR
        • Aug 2007
        • 1072
        One cooling plate on top and one on the bottom. You can also add a cooling fan. There is a lot of info on watercooling the Himodel 200A ESCS. (HM 200A)
        You can hold the cooling plates in place either by heat tranfer epoxy or heat shrink or epoxy...
        http://www.rcfastboats.com/
        • NorthernBoater
          • 811
          I am not familar with the Cuda 125. Only the FETs on the boards need to be cooled. How many boards have FETs on them?
          • jingalls007
            • 1015
            I know what your talking about, since that ESC used to be mine . I couldn't figure out any solutions for water cooling it. The one they sell on OSE doesn't like like it would fit since there are three circuit boards on that controller. What are you putting it in?
            • 6S HYDRO
              • 1320
              Its in my fuller's blackjack, yeah i was over at ray fuller's house yesterday and we discussed cooling that sucker, i got a cooling plate for the top board and i think im gonna slide a metal plate thru the middle and then solder tubes to both ends sticking out.
              • Flying Scotsman
                Fast Electric Adict!
                • Jun 2007
                • 5190
                Ray Fuller use to make a cooling kit, send him an e-mail. He may be able to help
                fastel1@cox.net
                Douggie
                • jingalls007
                  • 1015
                  That ESC was the replacement ESC Castle sent me a few years ago. Ray actually rigged my SV27 with the original cuda 125 up in Washington, that's funny, it's come full circle... almost.
                  Castle had issues with cooling the .125 hence the Hydra series so it's tough but Im sure you'll get it figured out. Good luck man, it's a great controller that can handle a beating for sure.
                  • 6S HYDRO
                    • 1320
                    fastel1@cox.net
                    Douggie
                    DIDNT YOU READ MY POST- I WAS OVER AT RAY'S HOUSE YESTERDAY. IM LUCKY ENOUGH TO BE ABLE TO GO OVER THERE ONCE A WEEK.
                    • DISAR
                      • Aug 2007
                      • 1072
                      You can also try a small cooling fan either 5V (power from receiver) or 12V, blowing into the ESC, if your water cooling is not effective.
                      • Flying Scotsman
                        • Jun 2007
                        • 5190
                        Paul, gently now. I did not read your post, obviously. What was his response? As he was the master of water cooling the Barracuda series.
                        Douggie
                        • 6S HYDRO
                          • 1320
                          I WAS NOT yelling, im in the architectural field and at work i always have on full caps. thats just how plans are done.
                          • NorthernBoater
                            • 811
                            Can you post some photos of the ESC so I can get an idea of what it looks like.
                            • Darin Jordan
                              • 8335
                              Here's how I've always done mine... .030" copper plate with 5/32" copper tubes soldered on. CPU Heat transfer compound on the plate, then slide them in onto the FETs and heat-shrink to hole them in place...
                              Darin E. Jordan - Renton, WA
