eletric motor
  • rcanuck
    • Apr 2009
    • 12
    eletric motor
    I recently purchased a ose 700 eletric motor with the brush and diode cooler installed. My previous motor was a grauper 700 which to connect the power wires I just used some removable eletrical clips. My question is since the cooling tubes were installed there is no room to hook up the power wires with clips, is the best solution to just solder the wires on?
    Hope someone can help me out
    Boon:
  • Meniscus
    Refuse the box exists!
    • Jul 2008
    • 3225
    As long as you don't need to use the ESC = Electronic Speed Control for more than one boat, then I'd just solder. Plus, you will get a better connection anyway. You can always unsolder later if need be.
    I hope this helps.
