There have been some comments made that if a brushless ESC is not run full out all the time, then heat could be an issue with the controller.
Last weekend, I performed a few experiments. Nothing overly scientific mind you.
Boat #1, 33" DF, Neu 1521, 4S2P, 100 Amp Pulso Speedo.
Boat #2, TS-2, Black Jack Motor, 4S, X-Power 100 Amp Speedo.
Boat #3, Stock SV-27 on 4S
For each boat I brought 3 sets of fairly identical LiPos.
Each boat was run 3 times in the following order. DF 33, TS-2 and then the SV. This allowed for more than ample time for each boat to cool down to ambient before it was run again. After each run I measured the temps of the speed controller.
1st run was flat out to simulate as close as possible race speeds for 4 laps
2nd run was trying to run each at about 1/2 speed speed for 4 laps
3rd run was "bashing" speeds, on plane, off plain, full speed, half speed, ,,, just plain goofing around for 4 laps
Again, I will state, nothing too scientific.
Results;
There was only about a few degrees difference between the temperature readings on all three different controllers after each of the three different runs.
The Pulso was around the 95- 100 mark.
The X Power was around the 90-95 mark.
The SV was around the 95-100 mark.
So, can we draw any conclusions from this, probably not, but the numbers speak for themselves.
So,,,,,in my not so scientific study,
I can conclude that it makes no difference if you run flat out or not.
Just thought I would post this as an "FYI".
Your results may (and probably will) vary.
Results;
I can conclude that it makes no difference if you run flat out or not. Just thought I would post this as an "FYI".
, if the water flows fast through the cooling system, the heat exchange is less than if the water runs slower (in a certain range or limit), so WOT there's less heat to dissipate (according to the above statement) but not as efficient cooling giving the same temp than when more heat has to be disspated but when the cooling is more efficient!
and see what others think!
