Where To Buy Capacitors
  • knpc
    • 566
    I need to replace the capacitors on a hydra 240. Does anyone know where I can buy them? Will a different brand aside from rubycon work?
    Rubycon ZLH 35v 390uf 105degC
    Thanks
    Kevin
    Rico 29, Sprintcat 34, Insane FE 30 Hydro, 43'' Aeromarine Conquest
  • jeff180
    • Jan 2008
    • 150
    I would also check radioshack they may or may not have it depending on how stocked they are.
    sad
    • tth
      • Apr 2008
      • 1510
      While you are replacing your present ones, you may want to add a few more. You know, for a little more insurance. Any local electronics store should have them. Personally I would stick with Rubycon if you can get them.
      • knpc
        • 566
        How would i go about adding more? It looks like its a tight space just to solder the 4 back on.
        • knpc
          • 566
          Thanks for the link. I'll check radio shack first, if I don't have any luck I'll order from there.
          • tth
            • Apr 2008
            • 1510
            Twist the leads together, then you solder them to the board. I would add at least 2 more. Any little bit helps.
            • Mel279
              • Dec 2008
              • 857
              I highly recommend you to use 35v 1000uf caps, more safer and can handle high ripple current
              • Ub Hauled
                • Aug 2007
                • 3031
                Yes they do.. but they are HUGE!
                • knpc
                  • 566
                  Thanks for the help. I'll see what I can find and give it a try.
                  • Mel279
                    • Dec 2008
                    • 857
                    Yeah they do, but it is much better than the stock one, like I said it can handle high ripple current, i have also hydra 240 and I've install one 35v 2200uf, so far no heat issue at all.
                    • Ub Hauled
                      • Aug 2007
                      • 3031
                      sweeeeeeet.. gotta love the lack of heat...
                      I cannot install huge caps on my 240... I have it in a VERY tight spot.
                      • knpc
                        • 566
                        Do you have a picture of what it looks like with the 2200 on it. I have plenty of room where my esc is located
                        • Mel279
                          • Dec 2008
                          • 857
                          here how I install it on my hydra 240, hope it help
                          • Mel279
                            • Dec 2008
                            • 857
                            Its the same function like those ETTI caps module, but if u wanna go for a simple and cheaper, just install it like I do, I even wanna try 4000uf if I can find one, its going to be pretty big
                            • knpc
                              • 566
                              Its hard to see in the picture how its wired. Are there two wires from each side of the cap going to the upper and lower board?
