i finally have a solid set up. thanks steve for the free cells to put together my packs.the e power 4500 are awesome. 12 are faster than 14 tenergy3800. my meanmachine is running 9xl, hydra 120 spinning a x445. i may change to a m series or 545 or 642.
the mean machine lives!
Tags: None
jesse ,i dont have any way of telling for sure. i am guessing mid thirties.she hooks up really well.and dont slow in tight turns. so i think i can raise the strut., i have ran 3-4 mins using between 2500 to 3000 mahComment
does it have any issues with spinning out? or hooking sharp on corners?"Look good doin' it"
See the fleetComment
no. i can spin out. its pretty easy not to though. left turn @ speed are a little scary.i dont do that very often ,right is where its at for me lol. shes dug in pretty good. jesse i seen you scratch build i also am going to try my scratch built oberto soon.i have a 11l and some small props maybe by the end of summer.Comment
you didn't see my scratch built oberto? Check my album she should be there. Franks plans, 1/12th scale?"Look good doin' it"
if its about boats or ony thing closely related or not so closely related my ocd makes me see them all lol. so the answer is yes i have seen it and thats why you will never see mine up close anyway!Comment
i mean't my boat is a mile'r i would want you to see it from a mile away.it might look as good as yours.Comment
I trimmed my 5" Speedmaster rudder down by 1.25". I don't have too much stick time on my MM but today I was shaking down the new 10xl/Etti set up and was running around 35 mph with a X640. She was carving nice tight turns without skidding but on the back stretch I don't know if I cranked the rudder too hard or what but she caught an inside edge and flipped over on her back. Water was pretty calm with only a slight ripple. Was this the dreaded hook I have read about??? Do I need to replace the rudder I trimmed down.Mike Chirillo
www.capitolrcmodelboats.com
Was your rudder vertical or kicked back a little? I have the Speedmaster 21 vertical and/or kicked back a little and turns very nice even at full throttle. NEU 1512/2D, 4s2p, 442,ETTI 150. Maybe also you turned too much, did it make like U turn?Twin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
http://www.rcfastboats.com/Comment
Nope, She was full throttle down the back straight and I just gave her a little adjustment to the right. I did a few full throttle U turns right in front of me and she turned real nice. Much tighter than on a race course. When she flipped, it looked like something tripped her up.Mike Chirillo
