graupner B24 finally ready!
  • SweetZ28
    • 1322
    Hi Guy's i just finished this looooong project I started putting this together and airbrushed it years ago but put it away and never worked on it since now and i just got it ready to run!!
    It's air cooled and i was wondering see the plastic fin that goes over the top of the prop would it work better if i cut that section off so nothing is up above the prop? the reasion why i am asking is because the turn fin unit looks to be like it should be used as a water cooling pick uo as there is a hole drilled in the back of the platform right behind the prop at the top.... I think there better boats used this rudder with water cooling....Take a look at the photos see what you guy's think... leave it or cut it off?
    THANKS
    WWW.PPRSLOTS.COM
  • SweetZ28
    • 1322
    Guess no one likes it?
    WWW.PPRSLOTS.COM
    • ozzie-crawl
      • Sep 2008
      • 2865
      looks nice and clean good job on the air brush work, i would leave the plate there it probably stops some flex in the unit
      cheers scott
      • domwilson
        Moderator
        • 4408
        I got one of those for my nephew. Post some videos when you get it wet.
        Government Moto:
        • SweetZ28
          • 1322
          Thanks guy's I am also working on the PHANTOM and now the MANTA ECO!!!
          WWW.PPRSLOTS.COM
          • domwilson
            Moderator
            • 4408
            Is that a "600" motor in it now? Are you running a 7.2v battery pack?
            Government Moto:
            • SweetZ28
              • 1322
              Hi yes it's the stock 600 motor i will be running 7.2v and maybe up to 8.4V ... the prop looks very cheap on the stock boat i think a CF40 will be good for it.
              WWW.PPRSLOTS.COM
