auto bailers
  • bustitup
    • Aug 2008
    • 3071
    auto bailers
    would like to get a survey of mean machine owners
    of all you guys using the bailers are you having any problems with your sponsons filling up with water when your boats stops out in the pond?
    I just tested my boat empty in my pool and the water rushed in very quickly almost to the top of the tunnel...it seamed with any weight at all in the boat would let the water come up over the top of the tunnel very easily......it was suggested that I plug the bailers up and I probably will but I'm curious to those that haven't plugged them up and how your dealing with it?
  • DISAR
    • Aug 2007
    • 1072
    In mine one was leaking one was not. I filled the the leaking one with silicon.
    http://www.rcfastboats.com/
    • TRUCKPULL
      • 2969
      If you need an auto bailer in a FE boat you have got other problems.
      Larry
      • Rumdog
        • 6453
        unloaded the plastic ball in the auto -bailer may not be contacting enough water to push it into the o-ring. try it with a little weight in the hull. the bailers should be completely submerged when the boat isn't moving.
        • NorthernBoater
          • 811
          An auto bailer in FE will not work very well. For it to work most effectively you can not have the boat sealed. You need to have air flowing into the hull to replace the water flowing out.
          • DISAR
            • Aug 2007
            • 1072
            The one that I left unsealed works fine- no water coming in from anywhere so I left it just in case something happens.
            Helps a lot when washing my MM.
            • HOTWATER
              • Nov 2008
              • 2323
              Larry
              I was just thinking the same thing!!!
              "Will race for cookies!"
              IMPBA D12
              My Gallery: http://forums.offshoreelectrics.com/album.php?u=1738
