Power Suggestions For 29'' Rico Mono
  • knpc
    • 566
    I'm starting to build a 29'' rico mono and need some advise on how to power it. I want to do this one as a budget build, sport setup, decent runtimes, 40-45 mph, 4s lipos. Not sure if a SV or BJ power system would work or an etti with a fiago.
    Thanks
    Kevin
    Rico 29, Sprintcat 34, Insane FE 30 Hydro, 43'' Aeromarine Conquest
  • Doug Smock
    Moderator
    • 5272
    40 to45 mph on 4s I would go with the Etti and a Feigao 9XL. X442 to a x445.
    The SV power system would work, but IMO you would fall short of your speed goal unless you abuse the equipment.
    Good luck, post some pics.
    Doug
    PS I just built a 31" Rico, you'll like the boat.
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • knpc
      • 566
      I tried a 9xl in another 29'' mono and had heat problems but that may have just been my setup. Is a 9xl in it a hot setup? If so what would be a bit more conservative? Here are some pics. Already installed carbon fiber and will post more pics when I start to build it.
      • Doug Smock
        Moderator
        • 5272
        You shouldn't have had heat issues unless you were running a large prop, if the boat was heavy, or running wet. Was the motor cooled?
        MODEL BOAT RACER
        IMPBA President
        IMPBA 19887L CD
        NAMBA 1169
        • tth
          • Apr 2008
          • 1510
          The setup in my Delta Force 29 is an 8xl with the etti 150 on either 4s2p 10,000man with an octura x440 or x442. This setup will yield mid 40's low 50's depending on water conditions. No heat issues at all.
          T. Hatch
          • knpc
            • 566
            The motor and esc were cooled and I used a x440 x637 and m445. The boat loved the m445 but smoked the esc. It may have just been something I did, it was when I first got into FE and didn't fully understand how to calculate everything.
            • Doug Smock
              Moderator
              • 5272
              The 9XL, Etti 150 and a x442 should be a bulletproof setup in that hull.
              I've run that setup with a Barracuda 80 with no problems.
              Good luck with her,
              Doug
              MODEL BOAT RACER
              IMPBA President
              IMPBA 19887L CD
              NAMBA 1169
              • ED66677
                • 1300
                agree with TTH, watercooled 8XL and cheap 120A ESC, 4S and K40/K42 prop works very well, the 9XL should spin an even bigger prop!
                check you COG, 20% should help if she doesn't get on plane and "burns power for nothing", I had the same on my 29" DF copy when the COG was around 30%.
                Emmanuel
                • Doug Smock
                  Moderator
                  • 5272
                  Thanks
                  Kevin
                  MODEL BOAT RACER
                  IMPBA President
                  IMPBA 19887L CD
                  NAMBA 1169
                  • knpc
                    • 566
                    It seems that an etti 150 and a 8xl or 9xl is the way to go. The question is which one? Whats the advantage or disadvantage to each one.
                    • ED66677
                      • 1300
                      the 9XL will be able to spin a larger prop than the 8XL, not a lot bigger though! IMO just enought to have a better prop efficiency and gain few mph at the end!
                      Emmanuel
                      • knpc
                        • 566
                        Sounds like the 9xl is the way to go. Thanks for the help.
                        • bustitup
                          • Aug 2008
                          • 3071
                          Df 36"
                          edit: sorry I thought I started a new thread but I messed up sorry for the jack
                          • ED66677
                            • 1300
                            does it exist? not sure!
                            Emmanuel
                            • Doug Smock
                              Moderator
                              • 5272
                              Good luck with your build !!!
                              Doug
                              MODEL BOAT RACER
                              IMPBA President
                              IMPBA 19887L CD
                              NAMBA 1169
