how do you eliminate the bec on the sv esc.... is it the middle red wire that plugs into the reciver
sv esc
Tags: None
Yes the middle wire is the correct one. You do not need to cut the wire to disable it. Just pull the pin out. -
yea but im using the stock radio and receiver and it glitches horribly..... i was told to eliminate the bec and it would stop..... just tried it and it looked ok on the bench test..... is it normal for the motor to get warm under no load at wot.... it got pretty warm60% of the time... it works every time!Comment
went to test it and it still glitched.... sooo bad infact it did circles without me even touching the throttle....same thing happened when i ran it with the bec....... i guess 14 cells on this motor and esc isnt possible without and fm radio huh??60% of the time... it works every time!Comment
it will get warm if you dont have cooling to it, also id try a new radio... mine loves 14 cells, with the BECrestoring the collectionComment
really?..... might be this servo is pretty old.... its from like 2000 its an old towerhobbies servo you guys think thats the problem..... it does this both in my cat and in the sv60% of the time... it works every time!Comment
i also have no problem if i run my other motor and esc on 14 or 16 only with the sv setup60% of the time... it works every time!Comment
