Andy & Paddy
  • egneg
    • 4664
    #121
    Paddy I have the new gps and will let you know how things go.
    IMPBA 20481S D-12
    • andym
      More Go Than Show Prop Co
      • 2406
      #122
      Chuck I think you will see 60+ with the right prop, these things hit 60 with very little effort
      • egneg
        • 4664
        #123
        Ran the boat today but it was way to windy and quite a bit of chop so I realy couln't run it WOT. Here is a pic with Douggie's motor installed
        IMPBA 20481S D-12
        • egneg
          • 4664
          #124
          I haven't posted in this thread for a while as I have had a couple of setbacks with broken wires and lost props. But I got things straightened out and went to the pond this afternoon because the water was flat and very little breeze. I have a smile from ear to ear. I would like to thank Andy, Paddy, Simon, Douggie, and all the others that helped me get this boat running.
          IMPBA 20481S D-12
          • Xzessperated
            • Apr 2008
            • 3060
            #125
            That is great news Chuck. That is 0.1kph faster than my best speed (see below) on a Chinese motor. Douggies old engine is honkin. Keep us posted as you continue your testing.
            Andy help!!! Chuck and Douggie are beating us.
            4s PolyQuest LiPo, Feigao 6xl, Octura X642 = 104 kph
            Several boats in various stages of destruction
            • egneg
              • 4664
              #126
              Paddy my setup ...
              4S Elite 35C, Feigao 8XL-modded, Octura M545-modded.
              IMPBA 20481S D-12
              • Xzessperated
                • Apr 2008
                • 3060
                #127
                Paddy my setup ...
                Chuck I think your ability to be able to run the M545 is a great benefit to your speed.
                As far as 2 blade props go the M545 is the fastest prop on both my Mr Krabs and my Neu powered Xzess 2.
                Andy told me to run a 7xl or 8xl instead of the 6xl motor but I would not listen. You will get longer run times on that 8xl. I run for about 10 seconds and then let the 6xl cool. Anyway I will watch the things you do and if necessary make some changes to keep close to your speed. It is good when there is someone else with a similar setup as the exchange of information saves both time and money on experimenting.
                • egneg
                  • 4664
                  #128
                  As you already know I have an .062 wire drive (as this is how it came) and the strut is 12mm from the bottom of the transom to the bottom of the strut. I am thinking Of making a tapered plug to better fit the wire for the front of the strut as it is open and I am sure it adds quite a bit of drag.
                  IMPBA 20481S D-12
                  • Flying Scotsman
                    Fast Electric Adict!
                    • Jun 2007
                    • 5190
                    #129
                    Now you Aussies know who rules. and sheep dip on the linkage as I suggested Chuck, probably made the difference
                    Also note that motor was modified by Peter Zicha
                    Douggie
                    • andym
                      • 2406
                      #130
                      I love those wire drives in my hydro,s, Paddy I still believe you can not run a prop that these hulls need with a 6xl ,just too hot
                      • Xzessperated
                        • Apr 2008
                        • 3060
                        #131
                        Andy I am thinking that if I can get Douggie to paint the motor then it will be faster
                        • andym
                          • 2406
                          #132
                          Oh Douggie will be so happy!! He probably has his finger paints out in anticipation, and we all know how his psychologist thinks it is great therapy
                          • egneg
                            • 4664
                            #133
                            I have been thinking about trying a 5S 5000mah 30c with the 8XL. Will this work or am I headed for trouble?
                            IMPBA 20481S D-12
                            • Flying Scotsman
                              • Jun 2007
                              • 5190
                              #134
                              Give it a whirl and you know the drill for temperatures and amperage draw
                              The M545 prop may be a problem.....Andy? or are you still busy in the Roo barn
                              Douggie
                              • andym
                                • 2406
                                #135
                                I would try a x645 or m645 with the usual mods, but a V series cupped to reduce that pesky extra lift would be very fast. 8xl on 5s MATE , probably work for SAW runs and then cooling down but the motor and esc would not last long.
