Stuffing tube liner trouble
  • drew
    • Dec 2008
    • 20
    Having trouble sliding a new teflon liner into my stuffing tube. The old one slides in and out nicely. Any tricks to get a new one in?
  • calcagno45
    • Mar 2008
    • 1006
    stretch it out, grab both ends are start to pull outwards, test fit, repeat as necessary.
    • tth
      • Apr 2008
      • 1510
      You could also hold it by one end and pull it through sandpaper to change the O.D. while not deforming the I.D.
      Edit: Or do like I do and run without a liner. Just get the size tubing where your flexshaft just fits.
      Hope this helps.
      • lomdel
        • Nov 2008
        • 708
        I also used the sandpaper method which worked fine. Then lube the inside of the tube with something and it'll slide in...
