Iddy Biddy Kiddy
well if ya wanna sell it i might be starting another cat project soon ill be happy to take it off your hands60% of the time... it works every time!Comment
Thanks for the offer. I have a shoppin cart made up here. I just need to decide what in my inventory to unload in order to off set costs. I will be using an 8S with an SV esc and my set of 2s lipos in parallel. I just need a rudder post and mount from fuller. I have one of the swept rudders that was cut down for the boat.Comment
That is an H2O Cat, the predecessor to the Alley Cat. I had one, and ran it on 6 cells and a Hacker 8S motor. It was quick, but since it is narrow keep the prop diameter small, use 1/8" props.
Not sure I'm feelin' it Tom."A quick temper will make a fool of you soon enough."
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Bruce Lee. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Comment
you can allways buy an alley cat. Ill set it up any way ya want. with the limited space inside this one i think the best result will be to have the most weight to the reer as possible with the extra room inside the hull for cg ajustment. cats need the weight in the back to fly the hull.Comment
you can allways buy an alley cat. Ill set it up any way ya want. with the limited space inside this one i think the best result will be to have the most weight to the reer as possible with the extra room inside the hull for cg ajustment. cats need the weight in the back to fly the hull."A quick temper will make a fool of you soon enough."
