prop choice for the cat
  • hammertime
    • 513
    right now im running an x440/3 on the cat and wondered if i should get something different...... right now everything runs cool and run times are really long and wondered if i should try a different prop for more top end and wich one should i try...... i think there is a lot of room for improovments for prop choice right now....any opinions would be much appreciated thanx
    60% of the time... it works every time!
  • hammertime
    • 513
    i was thinkin about a v937/3 too much??
      • 8011
      That is a high-lift prop, the cat will run poorly unless you change the setup dramatically. Try an x642 up to an m645 - these will give you higher speeds and reduced run time. Just watch the heat with any prop upgrade.
      • hammertime
        • 513
        note taken thanks
