Lehner 1950/6 Hi-Amp motor
  • Mel279
    • Dec 2008
    • 857
    hi
    have anyone ever use this motor?I know it can handle 10s lipo.
  • calcagno45
    • Mar 2008
    • 1006
    at 2090kv, I really don't think you want to be running 10s on that motor!! You will something!!
    Lehner's are top quality motors, like Neu's.
    What are you planning on running this in?
    • Mel279
      • Dec 2008
      • 857
      I have two boats, drifter s and mean machine, I think Im going to use it on my drifter s instead with 4s lipo, 180a esc and x442 prop. If all goes well, I'll use 6s lipo and see how it goes. I'll think about 10s later..hehe
      • Gerwin Brommer
        • Dec 2008
        • 918
        You'r setup works, BUT be carefull, it's a very very very fast setup !!( on 6S)
        • Mel279
          • Dec 2008
          • 857
          Yeah...its going to be insanely fastt!!!don't worry I'll standby the ambulance just in case if anything happen...lol
          • calcagno45
            • Mar 2008
            • 1006
            No no no, no way are you going to run 10s on that motor and not fry something! Thats 77,000 rpms, that motor is only rated up to 50-60K rpms!
            Stick to 4s, in either of those boats, they should fly!!!
            • Mel279
              • Dec 2008
              • 857
              For your info, that motor is rated at 85,000rpm, I've check from the website, this not a standard motor, it is design for Hi-Amp up to 35V, if Im not mistaken, but Im gonna go for 6s max, If I go more than that, the boat would go crazy for sure.
              • Gerwin Brommer
                • Dec 2008
                • 918
                More than 6S is not done.
                Maybe the motor can handle it, the boat, and you, can't.
                By the way : High-Amp Lehners : nothing special compared to the "old" Lehners.
                The only reason why Lehner introduced the High-Amps is to cover up a design-error.
                The older types are well known for loose connectors on the backplate.
                Therefore they now have "High Amp" motors, the wires are comming straight out of the windings, instead of a soldered connector.
                • Mel279
                  • Dec 2008
                  • 857
                  so, how do u compare with those NEU motor?is it better than lehner?
