Does anyone know what the Kv rating on the SV27 motor is. I could not find any contact info on Aquacrafts webpage.
Kv rating on SV27 motor??
Tags: None
I think its closer to 1800. Aquacraft is tight lipped on the specs.Steven Vaccaro
Where Racing on a Budget is a Reality!Comment
I'm 99% certain that these are the specs:
Stock No.: GPMG5315
Motor Dia. (mm): 36
Motor Length (mm): 56
Shaft Dia. (mm): 5
Shaft Length (mm): 15
RPM/V (kV Rating): 1800
Weight: 10.0 oz. (283 g)
Suggested Prop Size: 10x7E - 18x10E
Input Voltage: 14.8-22.2
Max Constant Current (amps): 50
Max Constant Watts: 1110
Max Surge Current (amps): 90
Max Surge Watts: 2000
No Load Current (amps): 1.9
Electrical Connector Size: 4 mm
I have the specs for their other motors as well... there are 3 in the 56-series motors (36-56); one is 1200KV, one is 1800KV, and the third is 2600KV... The 1800KV one is shown above, and is the one that makes the most sense, given this boats performance and 45-amp ESC...Darin E. Jordan - Renton, WA
"Self-proclaimed skill-less leader in the hobby."Comment
Stock No.: GPMG5315
Motor Dia. (mm): 36
Shaft Dia. (mm): 5
I have the specs for their other motors as well... there are 3 in the 56-series motors (36-56); one is 1200KV, one is 1800KV, and the third is 2600KV... The 1800KV one is shown above, and is the one that makes the most sense, given this boats performance and 45-amp ESC...Steven Vaccaro
Will the SV motor really handle 22.2 volts ??Grand River Marine Modellers
https://www.facebook.com/search/top/...ne%20modellersComment
At 22v its about 40k rpm. Most bl motors are good for that or better these days.Steven Vaccaro
Let me know Please:) how it holds up, I've got 4, 5000Mah 5S's being delivered soon for my V-24 mod and I would love to be able to use them with my Llumar, Blackjack and Super Hawaii as well, after of course , upgrading the speed controllers, I think the Aquacraft ones would die pretty quicklyGrand River Marine Modellers
I think the voltage alone would kill the aqua esc.Steven Vaccaro
i have a different esc.... ill try that motor on 16 cells first and move up..... it will be in the bandit cat60% of the time... it works every time!Comment
doby first test will take place tommorow...... vid as well..... im going to make some 8 and 9 cells packs first my esc can only handle 18..... wellll see!!.... i have 3 of these motors so i dont mind fryin one for science lol60% of the time... it works every time!Comment
Hammer; we all appreciate the sacrifices you are about to make ( hopefully not ) in the name of science:D :DGrand River Marine Modellers
