lubing the fexshaft?
  • all8up
    • Feb 2009
    • 17
    whats the best thing to use to lube the flexshaft? I am using high temp grease, and was thinking of using something lighter... thanks, in advance!
  • Boatman
    • Jan 2008
    • 796
    In my opinion what you are using is just about exactly what "Grim" sells. Just I like the white or clear grease as to not get any all over the hull.
    • Rex R
      • 992
      might be better to ask what not to use...folks have tried many things. haven't heard of anyone using 'personal lubricant'...I've used a blend of multi-purpose chassis lube & chainsaw bar lube. I've also used 'super lube'. axle grease/wheel bearing grease is probably not a good choice...ditto wd40 and 3-in 1 oil.
      • all8up
        • Feb 2009
        • 17
        I thought about trying 90 weight synthetic gear lube... don't know how well it would hold up, but I think it would have less drag..
        • sundog
          Platinum Card Member
          • Feb 2009
          • 878
          I'm using 'Gorilla Snawt' brand synthetic grease I obtained on ebay. It's waterproof and has teflon in it. I don't use a plastic liner in the stuffing box and this seems to work well.
          Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco Power
          • bustitup
            • Aug 2008
            • 3071
            What's wrong with grims? Its cheap
            • Rex R
              • 992
              in my case, well lets see about 25 yrs ago I bought a 5gal bucket of multi purp grease...I still have 4gal left :)
              • Boatman
                • Jan 2008
                • 796
                Dont get me wrong. Its good stuff in my opinion. I just wish they would have a hand holding the container. It will last me about 4 seasons it looks but, I wish I would have just stuck with the stuff I allready had in my hand.
                • Jeff Wohlt
                  • Jan 2008
                  • 2716
                  I grease them, wire drives as well, then drop some drops of oil down it. Makes it really smooth and fast.
                  www.rcraceboat.com
                  jwohlt5362@yahoo.com
                  • drew
                    • Dec 2008
                    • 20
                    I use marine wheel bearing grease. probably has allot of drag.
                    • kevakov
                      • Nov 2008
                      • 111
                      I run a combo, first I spray white lithium grease up the shaft with the thin red spary nozzle so it goes way up to the motor, then I cover the flex shaft lightly with the Grim Racer Speed grease, the two mix together very well and it last for two runs. White grease from a spray can is to light and the Grim really is too heavy by itself, but the mix of the two works great.
                      • ozzie-crawl
                        • Sep 2008
                        • 2865
                        i use lanolin wich is the oil from sheeps wool. it is thick like grease but as soon as it gets a bit of heat into it it thins out but doesnt spray every were. i dont regrease very often but i never have had rust on any of my flex shafts
                        • Bill-SOCAL
                          • Nov 2007
                          • 1405
                          Mercury Quicksilver 2-4-C multi-purpose marine lubricant with teflon. One tube lasts for better than 1 season running several boats.
                          Don't get me started
